Topics49,859
Posts837,505
Posts: 36 |
Hi All, Could anyone tell me is there a way on making the indicator "tick" louder. Also the indicator light brighter, but I think that will be the easy one. I have a1991 plus and during daylight the indicator light are so dimm as to be easily missed when not self cancelling. Also the tick is hardly audible at all. I have had a very close near miss recently because of this situation and am resolved to rectify one or other if not both.
Happy and safe New year to everyone,
Barry
Posts: 8,672 Likes: 411
Posts: 8,672 Likes: 411 |
CANBUS friendly LED indicators from Classic Car LED's to make them brighter. You can change to clear lens as well. Motorbike indicator beeper kit as here to increase sound.
Posts: 36 |
Hi Richard, thanks for reply, I think I may have made a misleading post. The lights are the dashboard ones not the actual turn indicators. Thanks anyway,
Barry
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
Barry fit a beeper. It is dead easy to do. Both Richard & I fitted them to ur 3.7l Roadsters.
Posts: 988 Likes: 14
Posts: 988 Likes: 14 |
An Audicator is the answer to the bleeping, they can be set not to sound straight away and to increase volume after a certain time and can be reset by touching the brakes. Buzzers can get irritating when having to keep an indicator on at traffic lights et al. I have been using one reliably for 20 years or so.
Brian
Jersey and Spain
Posts: 188 |
i fitted an audicator to my 2004 roadster. it had a habit of not cancelling on the left hand exit from roundabouts. solved the problem completely.
2004 Silver Roadster S1
Posts: 5,442 Likes: 132
Black Rat Charter Member
Posts: 5,442 Likes: 132 |
I fitted a M/C indicator beeper in the spare wheel space, easy to fit and cheap less than £10 if I remember correctly.
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Barry Hi Barry, many years ago I fitted an audible bleeper as I could nether see the dash board flashers or hear the clicking when using aero screens in strong daylight. It is a three pin unit that simply replaces the existing flasher relay and at the time Lotus seven owners were fitting them. Initially it was still too quiet so I drilled a small hole through each flat of the plastic casing then used electrical tape to seal them back up, untaped one hole at a time until I got the right volume, too many holes untaped and it sounded like a bin lorry. Simple and cheap,the unit is pre canbus at the age of your car and has no effect on the dash lights unfortunately. Had a quick search with no luck but there must be some available somewhere. If not perhaps Brian and Pauls suggestion of an Audicator will do the job.
1993 T16 +4 Lancia Blue.
Barry Hi Barry, many years ago I fitted an audible bleeper as I could nether see the dash board flashers or hear the clicking when using aero screens in strong daylight. It is a three pin unit that simply replaces the existing flasher relay and at the time Lotus seven owners were fitting them. Initially it was still too quiet so I drilled a small hole through each flat of the plastic casing then used electrical tape to seal them back up, untaped one hole at a time until I got the right volume, too many holes untaped and it sounded like a bin lorry. Simple and cheap,the unit is pre canbus at the age of your car and has no effect on the dash lights unfortunately. Had a quick search with no luck but there must be some available somewhere. If not perhaps Brian and Pauls suggestion of an Audicator will do the job. True I did that to my 97 T16 +4
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
An Audicator is the answer to the bleeping, they can be set not to sound straight away and to increase volume after a certain time and can be reset by touching the brakes. Buzzers can get irritating when having to keep an indicator on at traffic lights et al. I have been using one reliably for 20 years or so. Another vote for the Audicator, I really like the function of starting the beep cycle (which ramps up gradually) if you dab the brakes
