0 members (),
262
45
Topics49,860
Posts837,486
Posts: 7,931 Likes: 132
Posts: 7,931 Likes: 132 |
I've had a few dings knocked out on the clubsport and the superwoman panels are hard to work. If you can I'd aim for a replacement if they are available. I've heard that superwoman is often underestimated...
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
 Don't you love auto correct
Slowly going green
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Yep Foxterrier, Franky is spot on, Later cars, I think post 2006 have inserts fitted into the plywood rear wheel arch panels so no trim damage in the inside! Cooperman and asbojohn would be the way I would go as well. Get a new rear wing as that clout will have distorted the profile/shape of the rear wing. You'll send it out for repair and after it's been fettled and welded, filled and painted It will just not have the correct shape, might even need tweaking to refit and with all the subsequent damage that might cause. Just think it's too damaged for a good repair in heavy gauge alloy and it will be stretched all over the place. You'll end up spending more than you think, swearing at the God's when trying to refit it and when you stand back and look at all your cost and effort it'll probably be miles out on the wheel shape and position and stand out like the dogs spherical objects! You'll then be saving for a proper repair with more cost and kicking your self  Any chance of an insurance claim, If you have a specialist insurance they don't seem to steam the price for following years.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
All I would add is that a new wing will need trimming for width, which needs someone with experience. Otherwise the inner edge will distort.
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Go through the insurance and get a dealer to fix it. The cheapest is the dearest in the long run.
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Go through the insurance and get a dealer to fix it. The cheapest is the dearest in the long run. I did that with a repair to our then new motorhome. With the consequent increase in insurance premiums across all of our vehicles it cost us around three times what it would have cost had we had it repaired ourselves.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Give Allon white and Melvyn rutter a call and get a couple of ball park prices quoted, make sure you tell them its not an insurance claim and the job is a replacement rear wing and paint. Depending on where you are in Suffolk there is also Krazy horse and Richard Thorne.
Hapeth of tar and all that!
Hapeth of tar and all that! Funnily enough I'm off to Allon White's soon to have a couple of things done - I've always found them very reasonable. Thanks.
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
All I would add is that a new wing will need trimming for width, which needs someone with experience. Otherwise the inner edge will distort. One of those really thin cutting wheels in a 4" grinder, easy peasy and no distortion
Yep. I'm with you there cooperman! Dedicated cutting wheel and don't push it in aluminium and nothing will get hot! nor will the wheel clog. But if anyone is worrying about that part of the fit then really you probably haven't got the skill to undertake the job. Just in case though and for information if you are attempting it! The first job after removing the old wing is to fit the new unpainted wing and when that is all correct remove and get it painted and ready for re-fitting permanently. Probably a good idea to use new beading as well as you need to rely on that as a water seal. In the past I have used a low modulus soft set silicone to the inside edge on top of the bead. It is just a micro bead and can be applied before you fully tighten the wing fastenings into the wooden arch. Basically fit the wing in place and leave all fixings loose so you can move the wing. When happy that you can hold the wing into the fully fixed position apply the micro bead. Take your time, low modulus silicone doesn't cure like the stuff that smells of vinegar! The bead should be on the flat top seal section of the bead where it joins the bulbous part that sits outside and on the wing, in size about 1/8". Now start tightening everything up slowly observing as you go the whole wing position. when just moveable and you are happy with the position, ie. its all touching in the right place hold the wing by slightly tightening the wing to running board fixing ,the wing stay and the rear most fixing. Now you can tighten the fastenings that hold the wing to the ply wood inner wheel arch. I start at the middle or uppermost fixing. As you do this you must make sure that the wing is rising without being forced up into place or deforming the alloy and also that you are holding the beading in the correct place. When you reach a point of tightness that just holds the bead secure stop and continue with the rest of the timber arch fixings by alternating left of centre then to the right of the centre fixing., continue until all are fitted paying attention to bead position as you go! This will position the wing without stressing anything. Now you can tighten the remaining fixings. DO NOT OVERTIGHTEN ANY OF THE FIXINGS ACCOSIATED WITH THE WING BEAD, It will distort the alloy of the wing and over compress the bead causing it to bulge out onto the wing in that area! Just tight enough to hold it firm and no more. With a clean cloth wipe any silicone that may have squeezed out of the top of the bead, then finally with a creased fold remove as much of the excess form the top gap, you shouldn't be able to see any silicone evidence at all! When all is fitted and you are happy with the position I then remove the wheel arch to ply fixings one by one, starting with the top centre first. I inject a little squirt of the silicone into the hole and then refit the screw or nut etc. depending of Morgan's preferred method when your car was built. what ever the fixing method on your car there will always be a cavity created there which can hold water and if you look at the removed wing you will see the corrosive evidence of this around the fixing hole and as we know steel, alloy and water are ideal for causing galvanic corrosion. If you do that in a day then you are really doing well! Now go in and finish it tomorrow or another day!
Last tips: When you refit the lights change out those silly wire connectors MMC use for waterproof bullet connectors. Re apply the black wax body protection to the inner jointing areas to seal the alloy/wood joint. It is Dinitrol chassis black and you can buy a single aerosol spray can from Rejel on line. Lastly, use Three-in-one oil between the bottom of the bead and the alloy wing. This will protect the wing at the mounting surface from potential corrosion caused by water sitting there, erosion of the painted surface from the micro movement when the car is being driven and also squeaking noises from the same. Three-in-one is the recommended service lubricant oil by MMC although if I had leather covered beading I would probably opt for ACF-50
1 member likes this:
Fox Terrier |
