3 members (Pigiron, Wouter, ASPINTO), 309 guests, and 48 robots.
+8Rich 92
Topics49,839
Posts837,301
Page 1 of 5 1 2 3 4 5
#816291 26/01/25 09:52 PM
linklaw Offline OP
Hi all,
My 2005 S1 Roadster arrived at my house yesterday and I set the clock. When I pushed the set button, I noticed the hands went counterclockwise, instead of clockwise. I thought that might be correct, until I later noticed my clock was running in reverse. Instead of moving forward in time, it is moving backward. While there may be some circumstances where going back in time might be welcomed, this is not one of them. Anyone have any suggestions on how to correct the clock? I did have to jump start the car when it arrived as the battery was pretty dead. Thanks.
John Linkosky
John Linkosky
1995 4/4
2005 Roadster
2016 3W Superdry Edition
I'd hazard a guess the connections to the clock have been reversed. smile
1 member likes this: 1854sailor
X2 what Graham said...
Well everyone says driving a Morgan is like going back in time.....
From distant memory, I thought the terminals on the clock were different sizes so impossible to get wrong polarity, unless wires have been spliced in along route of course.
Until you said you had jump started, my initial thought was whether someone had connected battery wrong way round. Still worth checking perhaps?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Yep, I'm with the polarity too!
Odd question but where's it been?
I really want John to say Australia due to the coriolis effect grin2
Online NoMood
A little sceptical of the reverse polarity suggestions as per Deejay post. I know the pulse ones are polarity independant. I would drop dash and try removing the power feed to clock before re-connecting. You also have the opportunity of confirming polarity then.
linklaw Offline OP
Hello all and thanks for the tips. I disconnected the power (purple) wire from the clock, pulled the fuses and reconnected everything. I made sure the clock was not powered and when I reconnected it, no joy. It is still running in reverse. If the polarity was reversed, I imagine I would have fried the clock and gauges when I started the car. Will keep you posted if, and when, I figure it out. In the meantime, I am feeling younger every minute. I bought the car out of Florida. It was listed on BAT in December. I was the high bidder but did not meet reserve. In the month following, I was able to make a deal. Blue with red interior,
John Linkosky
John Linkosky
1995 4/4
2005 Roadster
Do you have an alternative battery to try ... yours may be failing .... since this happened have you removed the key? ... if not try pulling it out and replacing
