5 members (+8Rich, Joske Vermeule, TBM, Clipper, Adam12), 287 guests, and 40 robots.
Adam12 68
+8Rich 66
John V6 61
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,376
Members9,215
Rbt Aero8, Salmon, stevends
Page 2 of 15 1 2 3 4 14 15
Rog #776283 02/05/23 06:20 AM
Fine work Rog.
Good luck with fault finding on the PCB. I had a go at one of John V6 boards, but in the end it defeated me.
'09 Gen2 MINI Cooper ragtop
Originally Posted by Gordon D
That's looking good Rog, well done. I'm still contemplating how I'm going to resolve the issue I have with the fan blowing the fuse on the high setting. My fix at the moment is to try and remember not to put the fan onto the highest setting 😁
Hi Gordon. Just noticed your car being a 2014 model may be an early GDI engined one with BCU controlled heater fan motor. If so then my and Rog's previous comments don't apply.
Assuming it is the later model then the fan selector switch places a ground on either a slate wire (slow) or yellow wire (fast) which in each case is sent to the BCU as a trigger. The BCU in turn then powers either a green/slate wire or green/yellow wire to heater fan motor for slow/fast respectively. You could check the green/yellow wire plus connectors for short between BCU and fan motor. If nothing sinister found then maybe just increasing fuse 11 size from 10 to 15 amp may offset a marginal condition, as this protects the fan power into BCU.
Rog #776291 02/05/23 08:35 AM
Hi Richard. Thanks for taking the time to respond, my car is the last of the Duratec models so I'm not sure what the wiring arrangement might be! I have seen behind the dashboard and from what I can remember it looks similar to the pictures Rog posted.
Having read Gambalunga's thread on what seems like a similar issue I assumed it was the PCB that had failed?
I'll take the dashboard off sometime and post some pictures on a new thread so as not to take over this one. thumbs
Gordon Duguid
Rog #776307 02/05/23 11:31 AM
PM sent Gordon.
Rog Offline OP
Fine work Rog.
Thanks Graham I shall report back at some point but just sat here looking over it, it looks ok other than some growths on some of the component legs!
Roger
Rog #776312 02/05/23 01:48 PM
Very nicely done Rog. Not my specialist area, although I would have a go if necessary, and know who to ask !!
Rog #776316 02/05/23 02:39 PM
Do you really need to fix PCB now you have your robust home brewed solution Rog?
Rog #776323 02/05/23 05:12 PM
formerly known as Hugh Jorgan
Absolutely fantastic work...!!!
You need to start manufacturing the kit, there must be a market for it, it looks so good..!
Rog #776325 02/05/23 05:34 PM
I had rear foglight issues a while back. The light was flickering on and off. I’ve never actually used the rear fog as never been in need. Checked the whole system and I narrowed it down to the pcb unit behind the dash. The circuit board was loose inside so I glued it back. Worked ok for a while. As a pre MOT check it was failing again. Tried getting a replacement. Rutters didn’t have any, asked for photos.....factory part. Nothing coming so phoned the factory. Plenty in stock. Well not really as stock was for 1997 Plus8’s or earlier only. Mine’s a 2002. Can I have one and sort the wiring? No. Really? GRRRR.
Right then, Carbuildersolutions and a couple of others tried as they supply to kitcar builders. Before ordering ( about £30 max if I remember) one last look. Spotted a couple of iffy solder joints. Re-soldered them and ok ever since.
Still never used in anger but pre MOT checks only.
Rog #776327 02/05/23 05:44 PM
Great work Roger to make your own solution thumbs I'm very impressed
