1 members (Alastair),
330
34
Posts837,276
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Check main earth to chassis, braided cables can get clogged with crap which affects their efficiency. All replaced over summer, and extra one put in (no braided cables)
Just a thought looking at Richards diagram…if you have difficulty testing the three diodes, why not disconnect the hot wire from the diode triple point to the ignition light and pop a suitable diode in series with it to see if the light goes out when reconnected in that state. This is the trouble with my understanding of electrickery. I know the basics, but no idea about connecting a diode in series. I don't think I have one in my shed
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I found this: http://www.mgb-stuff.org.uk/sb.htmI think when the seat belt diode fails the ignition light stays on permanently, as I recall.
Yes - Paul's website is legend in the MG world - like GOMOG but more accurate. I've messaged the MG club to see if anyone has a photo of the location of the module so I can get to it easily.
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
This is for my MGB GT - I'm posting here as I know there are a number of electrickery experts whose opinions I value.
When driving my alternator light is very very faint, but still on. If I put on the windscreen wipers or washers it starts to glow more. However the alternator is still putting power into the battery - I have a plug in voltmeter and it's putting in around 13.8 - 14.4V. The voltage reading doesn't change when the wipers and washers are on.
I replaced the alternator last year and there has been no change.
In the last few days the alternator light has come on for a period of time - again, no effect on the charging, and still putting in 13.8 - 14.4V. Sometimes it turns itself off, other times, switching the ignition on and off cures the problem.
Any thoughts at where I should be looking? I'm assuming the problem would be with the lead from the light to the alternator? Broken or poor connection? But not sure why the light comes on with the wiper!
The car fuse box has been (badly) replaced and rewired at some point, and is in my fix list so may be a problem there? I think because you have already replaced your alternator Phil with zero change you can rule out the diodes - it has to be an existing earthing fault imho.
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Diodes can degrade as well as just full-on fail .... that might explain the variations you're seeing ... instead of simple 'fail to short circuit' it may be just failing and noisy on it's way out. Could give similar symptoms to a dirty connection.
Ps I'd look for a poor connection first ... if you've tried the wires, have you had the bulb out and cleaned it and its holder .. it is a series part of the circuit!
Posts: 5,432 Likes: 466
Posts: 5,432 Likes: 466 |
I might be inclined to disconnect the ign light connection at the alternator and use a test lamp one end connected to perhaps an unswitched live at the fuse box, the other end connected to the alternator ign light connection.... That way you will see if the temporary light, acts in a similar way to the original ign light in the variety of circumstances you describe, and might save you opening up your alternator to perform the diode checks...?
As ever just thinking in type and well past my sell by date on MGB thinking and much else..
As ever just thinking in type and well past my sell by date on MGB thinking and much else.. That's a plan. Unlike the old Morgan dash, the MGB is pretty enclosed and there's a fair bit of dismantling to do so that technique would see if that's necessary or not.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Just a thought, for Richard V6 to give his wisdom
As the OP has severely discharged the battery a few times beyond zero V, could this have failed a least one cell ? Under charge, alternator keeps systems running but never sees correct voltage pushing back so charge light glows ?
Also I would use a temp ammeter (or clip on version) to check if the alternator is putting out a good amperage
Richard ??
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
TBM not trying to muddy the waters further but I did have a similar issue on my narrowboat driving a high current alternator. The weight of keys on the ignition switch had turned it off. The alternator then started charging intermittently and given it's size (160 amp) I could hear the change of load on the vintage diesel driving it. There was a random cycle lasting a minute or two before it would cut back in again. The warning light followed this sequence as expected.
Point I'm making is the randomness of your issue could be down to intermittent and/or resistive feed from ignition switch to warning similar to my accidentally turned off ignition switch, the results of which are unpredictable as alternator appears to self energise for while then drop out again with sequence repeating.
Suggest therefore following up on your suspicions of this feed to warning light or just jury rigging a cable from live side of battery to warning light, remember to remove it though when you want engine to stop though. As your findings develop I'm more inclined to think this may be the issue rather than a failed diode. The ignition switch side of warning light feed receiving a varying voltage directly affecting its degree of illumination as the alternator maintains a more constant higher voltage to battery and other side of warning light. This would explain why it's brighter when you add load such as wipers as ignition side of warning light gets an even lower voltage.
