Topics48,362
Posts813,325
Members9,215
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
I'm busy sorting through the 3 tons of vintage motorcycle cycle parts my late Dad accumulated at the moment Arwyn Good luck with doing that Arwyn!
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 5,056 Likes: 318
Posts: 5,056 Likes: 318 |
You don't happen to have a set of engine mounts for a 5TA amongst it all? 😄 .... seem to have mislaid the one's for Mrs Image's bike while it's been in bits (haven't told her yet!) ... good luck with the sort-out ... there's always the worry that the odd piece of rusty metal about to be binned is actually the last existing double-acting flange bracket for a 1925 'Leak-Master' 5 cylinder 350 😀
Posts: 1,578 Likes: 105
Posts: 1,578 Likes: 105 |
Will check, we did have some 3TA/Tiger 90/5TA and Tiger 100 parts somewhere!
Arwyn
Posts: 769 Likes: 45
Posts: 769 Likes: 45 |
Does anyone have any tips for removing the bushings from the stub axle?
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
DaveW did an excellent guide some time ago, unfortunately the photos were stored on Photobucket and are no longer available. Still worth a read though. https://www.talkmorgan.com/ubbthreads.php/topics/484794/1
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Scroll right to the end for reposted images!
Scroll right to the end for reposted images!  Oops, sorry Dave! I should have realised you fixed it.
Posts: 611 Likes: 20
Posts: 611 Likes: 20 |
It's much kinder on the parts if you can push the old bushes out and the new ones in with a press but as Dave showes it can be done with other means. The other thing I made is a "pushing piece" (pic below) to push the bushes, in and out, with out damaging them. ![[Linked Image]](https://tm-img.com/images/2025/02/24/P1060364rs.md.jpg)
I'll try the socket idea. I tried the hacksaw idea, but it makes me nervous that I might score the tube.
Posts: 688 Likes: 62
Posts: 688 Likes: 62 |
Yep I'm with you there Pauly, I'm pretty good on the tools and don't mind LR suspension bushes etc but these hubs cost a packet and they look shed made too! But the tube size is small gauge in construction and one nick might cause a fracture when in use so the bushes have to be wound out as you say using the socket clearance method. Of course top and bottom bush mounts will not be in line and that is why a line reamer has to be used when reaming to fit the pins so that both are being reamed on the same axis, Ie. you can't ream one side then turn it around and ream the other as that will follow the tube orientation and they will definitely not be in line! I have seen a couple of hubs that were very out of alignment and one of the bushes when reamed was only just within the body of the bush. At first I thought it had a wear pattern but no, it was a reamer alignment correction! However I'm sure that chap will suffer a lot of lower bushes wearing out!
One tip here If you need to saw the bush for a relief cut. Mount the bush socket in the vice and make sure the hub body is below the jaws both sides then you can saw down through the bush and you won't contact the bush socket of the hub, might mark the vice jaws though! Often if you have a bush that is stubborn to shift this relief cut usually lets things move! Oh, and you don't need a lubricant when machining brass or bronze but for a smooth finish its best if the reamer has 10 cutting splines.
