10 members (IcePack, Mogdavid, CooperMan, OZ 4/4, DaveK, Joe Speetjens, CraigL, Mick Annick, Topline123, Morganmike), 311 guests, and 30 robots.
Adam12 69
+8Rich 67
John V6 61
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,368
Posts813,416
Members9,215
Rbt Aero8, Salmon, stevends
Well, Ripping out the very vulnerable return edge on the chassis that it bolts too! this return edge forms a large part of the integral strength of the chassis and in fact stops it cracking vertically. You may have heard about the rear spring hanger U-bolts that if not fitted and shortened correctly can impact with this edge at the rear of the chassis and cause failures there. It was once common practice to drill access holes through this return edge to allow easy access to those outboard U-bolt nuts and in effect remove the integral strength of the chassis, Thank God for ratchet spanners!
Dave, Yes my 2020 M\Y plus 4 fits your description too! Me thinks it might have been fitted with generic of the shelf flexies!
Difficult to see the articulation from photo's but the brake cable firmly cable tied to the BRB didn't sit well with me. I've had a similar issue from new and accepted that with steering other than straight ahead there will be some rubbing. I fitted cable tidy spiral plastic onto hoses each side and these are still protecting the aeroquip hoses after 33,000 miles.
John if you mean if it shears, well they don't tend to go anywhere as when the top oiler bolt is tightened they don't spin in the fitting so stay in the same orientation.
And of course if a shear was initiated I think you would have probably stopped! If the car was repairable then hopefully you won't have damaged the Chassis.
Grumpy2 Offline OP
Originally Posted by DaveW
Something has changed because in 2016 the flexible is nowhere near the BRB.
I can see two differences between yours and mine. The exit through the inner wing is further forwards on yours and it looks like your flexi is near vertical where it enters the calliper, mine is horizontal and pointing rearward towards the BRB
Grumpy2 Offline OP
[quote=RichardV6]Difficult to see
The cable ties hold the silicon tubing in pace over the flexi. There’s no mechanical fixing of the flexi to the BRB
Thanks for explanation and apologies for suggesting otherwise. Worth checking after some use the cable protection is long enough though. When I added mine the witness marks showed some degree of chaffing over a greater length given effects of both steering and suspension articulation. Check also the cable ties do not cause snagging.
Grumpy2 Offline OP
Everything moves freely without rubbing over the full steering arc, just the interference of the lines on the BRBs which I don’t like.
I’m speaking with Cain later today to get his thoughts hopefully.
If I don’t find a solution I think I’ll take them off prior to the MOT
Grumpy2 Offline OP
solution found thanks to Cain who suggested rotating the junction where the Flexi meets the fixed pipe on the inner wing.
looks like its done the trick
Cheers Cain
Cheers Cain
Sounds like a potential cure, just check (if flexi now goes over the BRB) that on full droop of susp travel that it's not stained
Grumpy2 Offline OP
It still goes under BRB, full and free lock to lock with sufficient clearance to allow for suspension travel
