10 members (DJC, nick w, Tweed19er, DaveK, Pyewacket, david nathan, Graham, G4FUJ, James B W, BobtheTrain, Tresco), 431 guests, and 41 robots.
John V6 68
DaveW 64
+8Rich 62
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,071
Captain Morgan, IRWIN
They are for a charger not jump starting. CTEK et al make comfort connectors. Get one with a fuse but only use it for low amp charging. If you use it for jump starting you will fry the cable as it isn't a large enough diameter.
See here
To jump start the car connect the positive to the starter motor terminal & the negative to the engine or the erth lead coming off the gear box to the chassis
2025 MG ZS EV aka Trigger
John is spot on. The cables I was referring to are solely for a CTEK, or similar, charger/conditioner and on no account should they be used for anything else. The cables should come with the charger.
Andrew
2013 Plus 4 ‘Alice’
2014 Plus 4 ‘Margot’ prev
2004 4/4 prev
1981 4/4 4 seater prev
Yes I have a CTek comfort connector permanently attached through the ply so that I can connect the charger to my AGM battery if not using the car for a month or so , just a few hours keeps it all happy .
99 plus 8 indigo
John, I appreciate what you said. I am well aware that the c-tek is for charging not jump starting. What I was thinking of was an extension to the battery terminals so that an emergency pack could be easily attached in the event of a flat battery whilst out in the wilds somewhere.
Reg
TBM Offline
Slightly different but my MGB has the battery under the seat. Before my recent rewire I would flatten the battery at least once a month over winter by leaving something on.
Fitted some heavy duty leads with an anderson connector that went into the boot/spare wheel well. Then had a set of 3 metre leads made up with an Anderson one end, and crocodile clips the other so I could easily jump of the other car, or a loose battery.
Like the one in this link - Ebay - Anderson
Black Rat
Black Rat
Reg, as JohnV6 said just connect your emergency pack positive to the starter motor terminal and negative to earth. That's what I do.
Keith
2013 narrow bodied + 4 Ruby.
Charging connectors such as Ctek use are good options, they are fused for safety but would not be suitable for a starting current. That's a whole new issue which could be fitted, but easier is to connect the start pack to the starter solenoid on the starter motor terminal, big red cable and a good earth on the engine which are easily accessible under the bonnet.
Look at the Ctek web site and all cable options are available even a battery state traffic light indicator. I took mine through a gland,flush fitting screw grommet on the vertical bulkhead face. this connector then allows me to connect the Ctec battery conditioner and or a trailing lead to supply a further power socket for in car use.
Before drilling for this access be careful as to where you you cut the hole as you need to consider what is behind the panel and good wire location using the rear hoop to clip the wires to between the battery and the access hole. I fitted my gland behind the passenger seat near the top outer corner.
