7 members (+8Rich, dherdebart, MATTMOG, James B W, Dullan, Image, Ian Wegg),
222
36
Topics48,337
Posts812,914
Members9,203
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
They are for a charger not jump starting. CTEK et al make comfort connectors. Get one with a fuse but only use it for low amp charging. If you use it for jump starting you will fry the cable as it isn't a large enough diameter. See hereTo jump start the car connect the positive to the starter motor terminal & the negative to the engine or the erth lead coming off the gear box to the chassis
Posts: 17 Likes: 1
Posts: 17 Likes: 1 |
John is spot on. The cables I was referring to are solely for a CTEK, or similar, charger/conditioner and on no account should they be used for anything else. The cables should come with the charger.
Andrew 2013 Plus 4 ‘Alice’ 2014 Plus 4 ‘Margot’ prev 2004 4/4 prev 1981 4/4 4 seater prev
Posts: 1,525 Likes: 37
Posts: 1,525 Likes: 37 |
Yes I have a CTek comfort connector permanently attached through the ply so that I can connect the charger to my AGM battery if not using the car for a month or so , just a few hours keeps it all happy .
99 plus 8 indigo
Posts: 5,366 Likes: 15
Posts: 5,366 Likes: 15 |
John, I appreciate what you said. I am well aware that the c-tek is for charging not jump starting. What I was thinking of was an extension to the battery terminals so that an emergency pack could be easily attached in the event of a flat battery whilst out in the wilds somewhere.
Posts: 6,056 Likes: 160
Posts: 6,056 Likes: 160 |
Slightly different but my MGB has the battery under the seat. Before my recent rewire I would flatten the battery at least once a month over winter by leaving something on. Fitted some heavy duty leads with an anderson connector that went into the boot/spare wheel well. Then had a set of 3 metre leads made up with an Anderson one end, and crocodile clips the other so I could easily jump of the other car, or a loose battery. Like the one in this link - Ebay - Anderson
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 5,107 Likes: 56
Black Rat Charter Member
Posts: 5,107 Likes: 56 |
Reg, as JohnV6 said just connect your emergency pack positive to the starter motor terminal and negative to earth. That's what I do.
Posts: 674 Likes: 60
Posts: 674 Likes: 60 |
Charging connectors such as Ctek use are good options, they are fused for safety but would not be suitable for a starting current. That's a whole new issue which could be fitted, but easier is to connect the start pack to the starter solenoid on the starter motor terminal, big red cable and a good earth on the engine which are easily accessible under the bonnet.
Look at the Ctek web site and all cable options are available even a battery state traffic light indicator. I took mine through a gland,flush fitting screw grommet on the vertical bulkhead face. this connector then allows me to connect the Ctec battery conditioner and or a trailing lead to supply a further power socket for in car use. Before drilling for this access be careful as to where you you cut the hole as you need to consider what is behind the panel and good wire location using the rear hoop to clip the wires to between the battery and the access hole. I fitted my gland behind the passenger seat near the top outer corner.
