8 members (Moggo, John V6, Hamwich, itsfrank666, LE52MOG, Grumpy2, GrandadC, Richardllll), 320 guests, and 40 robots.
Adam12 69
+8Rich 68
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,388
Members9,215
Rbt Aero8, Salmon, stevends
Page 4 of 4 1 2 3 4
Originally Posted by griffo
"Would you mind taking a few pictures of your power steering step up"
It wont be easy getting pix but I'll give it a go. I've never managed to insert pix in posts so they will have to go in the general photo gallery.
That's very kind of you much appreciated.
Prev '12 Plus 4 Sport OZZY
'08 Roadster FELIX
'06 4/4 70th LOKI
'77 4/4 SEAMUS
'85 4/4 MOLLY
See gallery.
1 member likes this: JohnHarris
Originally Posted by Colsmog
i’ve just had the CDD power steering unit fitted to my 2004 S1 Roadster, just to help this old boy help to overcome that Arthur bloke who messes up your joints on shoulder and hands; When I brought the car in 2021 it had a 15” Motolita wheel that perhaps will give you some idea of the effort required at low speeds. I changed this to a14” wheel and it was still a struggle understandably.; the ps unit is quite a game changer, extremely easy low speed turning, with no effect noticeable when going 50 60.70, , .I woulld highly recommend this on the early Roadster.
I also sought information and advice on changing the manual gears box to automatic, as I have that bloke mentioned above affecting both my ankles with imminent ankle fusing or replacement to the left.. However this is not possible mainly due to the fact that the programming for the auto box on the Ford V6 is not available and the bulkhead would have to be modified to fit the auto box, the cost would be to much to justify.I am aware of an auto control to move the gear knob, but not for me.
Yes yes I know I can buy a MY22 auto CX for around 62K.BUT I thoroughly enjoy ability to drive a proper Morgan which is totally reliable, and fun.
Who fitted the CDD for you Colsmog?
Hi Stewart, fitted by Graham King T; 07776483137our local Independant Mog service one man band, in Chelmsford; he had just done another members Roadster and is very good. And just under £3k for the ps unit, plus oils etc. Labour was £900, this included full service and Mot. He had the car for 5 days.I think.
Colin.
RX450 easier ezchair.
2004 Roadster.CM51ERS.
Thanks Jon, It’s just such a nice car!
Regards Colin
Colin.
Electric power steering is definitely the way forward, it's cheaper because you're not fitting a pump and replacing the rack as with a hydralic system, offers a more flexible instalation for the same reasons, and finally good systems are also easily tunable to an individual driver's needs/preferences.
My Mulfab front wishbone conversion uses a 2.7 turns lock to lock Escort rack, which I understand is already considerably faster than a standard Morgan rack, however, my unasisted steering remains perfectly manageable even with the smaller diameter 13" thick rim wheel I recently fitted.
https://www.talkmorgan.com/ubbthrea...rk-steering-wheel-offset-ring#Post814029
But my plan is to fit an even faster rack at 2.4 turns lock to lock, this is easy and cheap to do when you have a Mk1/2 Escort rack as a wide variety of ratios are available off the shelf from the likes of Motorsport Tools and Retro Ford etc, but do I suspect when I do go 2.4 LTL Monty's steering will finally become a little to heavy at parking speeds.
So my plan is to go with a speed sensitive system from Lite-Steer.
https://litesteer.com/project/morgan-4/
In my opinion, a good ectric power steering conversion should always be speed sensitive because the truth is you only really need assistance from 0-15mph tops, above that speed and for a reasonably fit driver, if your steering is still heavy something is likely fundimentally wrong with the car. A ccorrectly calibrated speed sensitive system should ramp down the assistance from a maximum mechanical advantage at 0mph, to zero assistance at 15mph as after that any assistance is actually undesirable.
On a drivers car like a Morgan, and at anything above 15mph, ideally you want to be returning to the direct feel on an unassisted rack, and this is exactly what you get with a well calibrated speed sensitive electric power steeing system. Lite-Steer seem to have developed the right solution at the right price, they also have experience fitting their speed sensitive kit to many a Morgan's steering column, which in Monty's case remains factory standard.
This all means Lite-Steer's Morgan instalation and bracketry will have already been thoroughly developed and well tested, if the OP is anywhere near East Sussex I would definitely reach out to Neil Oakley of Lite-Steer to see what he can offer.
Good luck with the project, and please keep us posted on the results thumbs
Dave.
I am aware that several power steering units across a range of vehicles including a 2012 4/4 have been installed by Morgan Owners in Western Australia and they rave about the results....
very successful
I helped a friend of mine build a Triumph special with an LS2 engine and he used an electric rack from a Vauxhall Corsa, which seemed to do the job , much to my surprise..
Page 4 of 4 1 2 3 4
