1 members (Johnnyboy), 192 guests, and 29 robots.
+8Rich 102
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,255
Smed., Spanner Juggler
Page 20 of 20 1 2 18 19 20
Much appreciated as always!!!! Thank you for keeping this list alive and current.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Latest update for the Alternative Parts List. Some additional information about fuel filler caps, exhaust flexi adaptors (found out from my own experience!) and some rear wheel and tyre information. Any information you have that may help other owners, please email it to me for inclusion in the next update.
https://www.dropbox.com/scl/fi/u0m0...but1a4r93py8ad6&st=6t88h7em&dl=0
2 members like this: Bunny, Stevo666
is the an alternative to the reed valve, as it is currently made of unobtanium
Rodger
2004 Plus 8 (wife's)
You are correct Rodger......unobtainium! I have had a look as well. There may be the odd one in a packet on a shelf somewhere but not easily available. I was waiting for you to come up with an alternative for us 😁.
There are a number of reed valves available for other engines but I don't know of a direct replacement sadly. They are not that expensive generally and it may be a case of finding something close in the same gauge material and trimming it to size? Fortunately, at the moment, mine still works, so I am in the "if it ain't broke, don't fix it" group. Not a big help but if you do come up with an alternative that works, please let me know.
It is simply a flat piece of thin spring steel. Mine seemed to improve when I flipped it over. S&S makes a very different reed valve (and $$$) for older harleys
Rodger
I also believe the Fuel tank sender (280mm) VDO 224011000280G (Europa Spares) is now also made of unobtainium!
Does anyone know what Morgan are now using for part E280004 ?
https://morgan-kent.com/product/sender-fuel-tank-vdo-2str-89-97/
If anybody needs a fuel sender unit, 280mm, we have them in stock at office@m3wserivces.com
