11 members (DCH, Burgundymog, B3MOG, +8Rich, Bishmog, HawkMog, OZ 4/4, Anonymouse, Tony Quinn, BLUE+4, Hamwich),
415
SORN
New
Topics48,375
Posts813,508
Members9,215
Posts: 198 Likes: 29
Posts: 198 Likes: 29 |
Oops, yes, Tuesday! Unless the fuse turns out to be the issue. Good suggestion, thanks.
MY2023 Plus Six "Rachel" MY2022 Volvo C40
Well, it's not the fuse. A call to MMC on Tuesday, then!
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
Sorry to hear that. Does the USB port work? If not the power supply might be loose.
On the MY23 Plus Six the Bluetooth module and USB have different fuses. I think the power supply to the Bluetooth was either dislodged or removed and not put back when the dash was removed by MMC to check the earthing behind. They were chasing a "Drivetrain" fault which they thought could be either fuel supply or earthing, and starting at the back were working their way forwards. Good news is the Drivetrain fault seems to be solved, but frustrating that in doing so another, albeit less serious, issue has been created
Fixed. A call from Morgan Service: "Disconnect the negative terminal of the battery, leave it for five minutes and then reconnect it." Simple solutions are best  And in disconnecting the battery I tested the Global Telemetrics response team ... "We have detected that the battery has been disconnected on your Morgan"
And ... it's happened again. Called in to a petrol station to fill up with E5 on the way down to Mogfest, Bluetooth was working when I got there, wasn't when I left. I didn't have the tools to do anything with it over the weekend, so now it's negative terminal off time again, but a call in to MMC as this is treating the symptom, rather than the cause!
Posts: 3,425 Likes: 26
Posts: 3,425 Likes: 26 |
I wired a radio in to the amplifier and find it much better than the Bluetooth. I get all music from the phone as well through the radio and all is controlled by the app which came with the pioneer radio. The real benefit is that full control of the speakers comes through the radio as is front to back balance. P M me if you want further details. Cheers!
Thanks Robbie, I’ll send you a PM re the radio. The disconnect worked, but is a sticking plaster. To make it easier when, not if  , it happens again, I fitted a Richbrook Discarnect battery master switch with fuse link. It will make it much easier to disconnect the battery and has the added benefit (as and when needed) of providing additional security against theft.
