0 members (), 280 guests, and 42 robots.
Topics49,860
Posts837,486
Jonny72
I'm still having problems with my 4 x 4 2001 Morgan indicator lights, I'v brought a new unit, ( Black three pins ) does anyone have an idea where i can find the unit ether in the engine bay or dashboard
What are the symptoms ?? Kevin
Have you taken out each indicator bulb and checked the holders for corrosion as this is usually where the fault lies
Hi Jon, No I still have to check all bulbs, I've had a number of problems starting the car even though I've had a new fuel pump fitted, the car start OK now, but needs a good run, everything seems to be OK apart from the indicators, thus unable to get an MOT just cant find the three pin flasher unit, its driving me nuts !!
Try tracing the wires from indicator switch Kevin particularly the green/brown one if you can find it. Generic colours are shown below with typical installation of three pin flasher relay as used on Series 2 Land Rover.
It's possibly buried in the loom under/behind the dash. Good luck with finding it.
Still wondering who did the four wheel drive conversion (4 x 4) laugh2
Thanks to RichardV6 and Graham, I think we have a few sunny days comin again so will get the car of of the garage and have a look,
