2 members (DJC, Socalm3w),
363
Posts837,277
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I applaud your skills Arwyn.
1 member likes this:
Arwyn Williams |
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
I like the mounts, plain and simple, will make the spots fit in nicely Arwyn. Isn't it funny that in making things look simplistic the engineering behind it is more complex.
Posts: 61 Likes: 3
Posts: 61 Likes: 3 |
Hi again, it turns out to be 7/16" 28 TPI. We then assume it's UNEF, which has 28 turns per inch for the 7/16". A friend of mine will forward such a nut. Hopefully it will fit. Will let you know. Cheers /Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
Posts: 61 Likes: 3
Thanks a lot Arwyn, very nice of you. If the UNEF that a friend is forwarding doesn't fit, I would be grateful to obtain a BSB from you. I'll let you know. Cheers /Finn
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Did you measure the threads with a gauge, or just do a count? 26 vs. 28 TPI might be difficult to eyeball. Thanks a lot Arwyn, very nice of you. If the UNEF that a friend is forwarding doesn't fit, I would be grateful to obtain a BSB from you. I'll let you know. Cheers /Finn
Posts: 61 Likes: 3
So, the nut forwarded by a friend turned out not to be 7/16" after all (it's smalller). Arwyn, I would be very grateful if you could forward me the correct nut, as it seems to be next to impossible to locate it here in metric Denmark. I counted 28 Tpi, but to be honest it could also be 26, I mean where to start the count and I'm not a prof craftsman after all. How should we proceed?
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
So, the nut forwarded by a friend turned out not to be 7/16" after all (it's smalller). Arwyn, I would be very grateful if you could forward me the correct nut, as it seems to be next to impossible to locate it here in metric Denmark. I counted 28 Tpi, but to be honest it could also be 26, I mean where to start the count and I'm not a prof craftsman after all. How should we proceed? No worries, please send me your address and I'll make one tomorrow night and send out to you Kind regards Arwyn
Posts: 61 Likes: 3
Morning Arwyn, just posted a PM. Cheers Finn
