0 members (), 215 guests, and 79 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#823509 14/05/25 07:21 PM
CRL Offline OP
Hi,
Has anyone changed the front brake pads on a Plus Four? If so, i'm presuming I can just remove the pins & clips, but, how on earth do you get the pins out? You can't get at the back of them to tap them out.
thanks in advance.
CRL #823561 15/05/25 07:35 PM
I changed the pads. You have to remove the brake caliper to remove the pads. I advise you to use good quality pads. I no longer have the reference, but they are 406 coupe pads. Be careful, this is the version with thin linings. At the rear, they are Mitsubishi Lancer evo 8 pads.
CRL #823671 16/05/25 07:59 PM
Wow ! so a CX has Peugeot brake parts...no wonder they had brake issues, it was doomed from the point of build frown
CRL #823675 16/05/25 08:14 PM
The 406 Coupe V6 ran well and braked well.
gaston #823712 17/05/25 12:24 PM
CRL Offline OP
thanks Gaston, ill take another look. Most helpful.
gaston #823731 17/05/25 06:08 PM
Sorry Gaston, bit of English (Yorkshire) humour grin2
