Topics49,883
Posts837,822
Posts: 5 |
Hello, I have a 2008 Plus 4 with a vinyl hood. At the back of my vinyl hood I have a rubber seal that sits between the rear of the hood and the painted rear panel of the car. The rubber seal has become unstuck from the bottom of the roof frame. Would anyone be able to recommend an adhesive to solve this? Thank you. Tony
Posts: 8,690 Likes: 497
Posts: 8,690 Likes: 497 |
Welcome to TM,
Try some clear UHU which is readily available - but make sure you clean off any old glue and degrease with something like meths spirit
Posts: 5 |
Posts: 27,825 Likes: 753
Posts: 27,825 Likes: 753 |
If the old glue is brown you need a neoprene adhesive like Bostick
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
The problem with European standards is that general public neoprene glue is destroyed by water, avoid gluing in unventilated areas because real neoprene can make you hallucinate, the only place where I managed to find real neoprene is Ali I have just recommended 5 pots because I see that it will soon disappear from their sale. https://urls.fr/1xh44t
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Use Dunlop 1358 or equivalent from a car/boat trim supplier.
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 322 Likes: 3
Posts: 322 Likes: 3 |
Another option is Weicon GMK 2410
--------------------------- Mike Smith
2007 +4
Posts: 2,117 Likes: 68
Posts: 2,117 Likes: 68 |
Hmm Isn“t Venyl/ Everflex a kind of PVC? I did not find any glue for PVC and another material that has lasted a long time on the surface of Venyl.
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
The properties I look for in this situation for glue is waterproof and flexible. I had good results with Unibond eXtreme but this seems to have disappeared from the market. I'm now looking at Gorilla contact adhesive which ticks the boxes.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Exactly and I bet the previous glue was brown like evostick or bostick
