New
Topics48,365
Posts813,346
Members9,215
Posts: 5 |
Hello, I have a 2008 Plus 4 with a vinyl hood. At the back of my vinyl hood I have a rubber seal that sits between the rear of the hood and the painted rear panel of the car. The rubber seal has become unstuck from the bottom of the roof frame. Would anyone be able to recommend an adhesive to solve this? Thank you. Tony
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Welcome to TM,
Try some clear UHU which is readily available - but make sure you clean off any old glue and degrease with something like meths spirit
Posts: 5 |
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
If the old glue is brown you need a neoprene adhesive like Bostick
Posts: 756 Likes: 9
Posts: 756 Likes: 9 |
The problem with European standards is that general public neoprene glue is destroyed by water, avoid gluing in unventilated areas because real neoprene can make you hallucinate, the only place where I managed to find real neoprene is Ali I have just recommended 5 pots because I see that it will soon disappear from their sale. https://urls.fr/1xh44t
Posts: 181 Likes: 1
Posts: 181 Likes: 1 |
Use Dunlop 1358 or equivalent from a car/boat trim supplier.
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 310 |
Another option is Weicon GMK 2410
--------------------------- Mike Smith
2007 +4
Posts: 2,064 Likes: 57
Posts: 2,064 Likes: 57 |
Hmm Isn´t Venyl/ Everflex a kind of PVC? I did not find any glue for PVC and another material that has lasted a long time on the surface of Venyl.
Posts: 296 Likes: 4
Posts: 296 Likes: 4 |
The properties I look for in this situation for glue is waterproof and flexible. I had good results with Unibond eXtreme but this seems to have disappeared from the market. I'm now looking at Gorilla contact adhesive which ticks the boxes.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Exactly and I bet the previous glue was brown like evostick or bostick
