Topics49,847
Posts837,391
Posts: 33 Likes: 9
Posts: 33 Likes: 9 |
Hi, Has anyone changed the front brake pads on a Plus Four? If so, i'm presuming I can just remove the pins & clips, but, how on earth do you get the pins out? You can't get at the back of them to tap them out. thanks in advance.
Posts: 208 Likes: 7
Posts: 208 Likes: 7 |
I changed the pads. You have to remove the brake caliper to remove the pads. I advise you to use good quality pads. I no longer have the reference, but they are 406 coupe pads. Be careful, this is the version with thin linings. At the rear, they are Mitsubishi Lancer evo 8 pads.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Wow ! so a CX has Peugeot brake parts...no wonder they had brake issues, it was doomed from the point of build
Posts: 208 Likes: 7
Wow ! so a CX has Peugeot brake parts...no wonder they had brake issues, it was doomed from the point of build  The 406 Coupe V6 ran well and braked well.
Posts: 33 Likes: 9
thanks Gaston, ill take another look. Most helpful.
Wow ! so a CX has Peugeot brake parts...no wonder they had brake issues, it was doomed from the point of build  The 406 Coupe V6 ran well and braked well. Sorry Gaston, bit of English (Yorkshire) humour
