7 members (rossocorsa, Boaty118, MATTMOG, Clipper, Tresco, nick w, RobC),
246
33
Topics49,909
Posts838,128
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
My Defender Td5 is running beautifully, but at 130K+ miles I'm starting to think maybe I ought to replace the injector harness.
I know there are Td5 owners out there, so I'm wondering what to go for. OEM harnesses aren't sealed, but the sealed ones you can get from places like Paddock Spares are pattern jobs.
Any recommendations?
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
Thanks, I'm a member of LandyZone but for some reason I didn't think of asking there first. I think I'll check the ECU connector first and if there's no evidence of oil I'll leave well alone. It's not like you get a sudden failure if the loom starts wicking oil anyway.
Posts: 1,035 Likes: 121
Posts: 1,035 Likes: 121 |
If you have no symptoms, ie a miss fire type effect then just pull the plug from the end of the ECU and check to see if it shows oil tracking up the lead. it's usually obvious. if you do, then change it but if it's clean then no need. It may have already been changed, early versions were awful and 35-40,000 mls would be good. Sealed versions have also been known to allow oil to track up to the ecu. In the early days the cost was huge but now about £60.00 or less. The pattern parts seem to be fine and its an easy job, nothing like LR led owners to believe when no one knew any better and you'd get a bill for £350.00 in very early 2000's. Yes it runs inside the rocker box cover but its a simple plug and plug fit! No you won't have a totally disabling failure when you get symptoms but it can destroy the ECU if nit addressed fairly quickly.
1 member likes this:
Hamwich |
Finally got around to checking it. Dry as a bone, not a trace of oil, so I've decided to leave well alone.
