10 members (Graham, G4FUJ, CooperMan, Morganmike, DaveW, MJF, Mike D, PaulV, +8Rich, Moggo, sprinty),
274
149
Topics49,869
Posts837,658
Posts: 528 Likes: 85
Posts: 528 Likes: 85 |
I had an issue where the engine would occasionally cut out as it warmed up, it would start again but not running on all cylinders. Give it a few minutes and all would be OK. Took it to MMC and they looked at the fuel and earthing. Now solved, with the most likely cause one of the earthing points on the basis that (a) nothing was found wrong on the fuel and, (b) earthing faults were a known issue on the Plus Six.
Why that would only be when it was warming up is a mystery to me, but it could be related to your problem I guess. When you start the car a high amperage and quite a lot of stored charge is used, then during the first few minutes the alternator kicks out max charge to try and replenish the battery - this could show up in the faulty earth, and I suspect complex Mogs like a CX may well have a dedicated alternator earth connection Cheers Jon.
Plus Six "Rachel" Volvo C40
Posts: 206 Likes: 15
Posts: 206 Likes: 15 |
Pluged in my OBD2 trader, thanks for the info chaps. No error codes, even thought the engine management light was lit.
Got me thinking on some BMW cars if you change the battery you have to program it in, does anyone know if this applies to a Plus Six?
My new battery is a 096 /100 type that replaced a 096.
Previous Mog Plus 4 Fiat Twin Cam. Plus Six
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
On my plus four disconnecting has not needed reprogramming. I then changed the battery without reprogramming
Mark at MMC got me to disconnect the battery on my Plus Six to reset the Bluetooth connection. Worked fine as a solution, and created no issues. So, no, you don't have to 'program it in'.
Could someone with a newish Plus Six please take a look and tell me what type of battery was installed by the factory? Specifically is it a Type 096 AGM.
MY23, it's a Banner Running Bull 70Ah AGM Leisure Battery.
MY23, it's a Banner Running Bull 70Ah AGM Leisure Battery. Thank you for the information.
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
MY23, it's a Banner Running Bull 70Ah AGM Leisure Battery. Are you sure? “Leisure” batteries are normally for caravans and motorhomes and not designed to produce the starting current for an engine.
Yep, just double-checked. This is the battery: Plus Six Banner Battery and here is the datasheet: Banner 57001 datasheet
The spec of battery (Running Bull) is fine and correct but I still think the supplier has mis-named it. Banner Leisure batteries are meant fir caravans etc and are branded as “Energy Bull” not Running Bull.
