Topics49,843
Posts837,339
Posts: 40 |
Sewin Yes ive give the rack plenty of the red and tacky grease i use on the king pins its hard to get hold off .When i first got the car the suspension was hard and steering stiff with lack of use but 100% better now .I think the gators split and get missed on mots because they split at the top un seen.ps not got to the ferry yet but we will this year thanks for the info weather permitting.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
Personally I think Red n Tacky is a bit stiff for steering racks, better to use a semi fluid grease as the stiff stuff gets forced out of the wear points and stays out, you need something to gently flow
ps, anyone found a source of the Red n Tacky, as it went NA last year ?
Posts: 40 |
Got it off Ebay two years ago looks like you have to send for it from U S A.
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
ps, anyone found a source of the Red n Tacky, as it went NA last year ? https://www.amazon.co.uk/Lucas-1057...2281435177138&psc=1&gad_source=1I think there was a fire which interupted supply, but seems OK now
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Sewin Yes ive give the rack plenty of the red and tacky grease i use on the king pins its hard to get hold off .When i first got the car the suspension was hard and steering stiff with lack of use but 100% better now .I think the gators split and get missed on mots because they split at the top un seen.ps not got to the ferry yet but we will this year thanks for the info weather permitting. I use Morris Deltaplex 2EP; a red, extreme pressure grease that I have used for years on my king pins. Readily available online from Opie Oils down in Redruth, Cornwall
1 member likes this:
CooperMan |
Blink'n ek...twenty five quid !! I'm from Yorkshire you know Just checked the garage and my last tub says £6.99, and I get 10% off I'll be swopping to Morris, thanks Doug
