5 members (+8Rich, Pyewacket, B3MOG, Liam1961, Haggispeed), 288 guests, and 40 robots.
+8Rich 92
John V6 49
Posts837,986
#825334 13/06/25 03:54 AM
I have a set but don't think I will ever install them...is there any interest in these? I know that there were challenges getting the remapping done. Did Morgan ever release the locked information on the ECU?
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
AZJowett #825386 13/06/25 08:37 PM
I was also able to get the 569 cams when they were available. Krazy Horse sells an unlocked S&S ECU with their Stage 2 tune on it that I was also able to order. I think they still have these in stock but they are not cheap. I haven't installed all this on my car quite yet, but I understand the engine runs more smoothly with the 569 cams and tune on it.
Craig - Texas, USA
2026 Plus Four
2021 M3W
AZJowett #825462 16/06/25 12:26 PM
No, the unlock code was controlled by S&S and never released.
Red Leader drive
Chris99 #825497 16/06/25 09:34 PM
Sent: Monday, June 16, 2025 1:54 PM
To: Scott Morrison
Subject: Re: 2018 Morgan 3 Wheeler ECU
Hi Scott,
We cannot unlock the factory ECU on a M3W.
Morgan did offer a factory Stage 2 calibration that ran the 569 cam. The calibration does exist and it can be flashed into the factory ECU without unlocking it but it would remain a locked calibration after loading it.
That calibration belongs to Morgan and is not directly available from S&S. You would have to contact Morgan on that specific calibration.
Thank You,
Technical Support
S&S® Cycle, Inc. | 14025 County Highway G, Viola, WI 54664
Office 608-¬627-1497
On Mon, Jun 16, 2025 at 12:19 PM Scott Morrison wrote:
Good morning,
I am the current owner of a 2018 M3W with the S&S 121 X-Wedge Engine.
Now that this model from Morgan has been discontinued, I am searching to see if I can get the UNLOCK code for the ECU.
I have the 569 Easy-Start Cams and, without the unlock code to reprogram the ECU controller, I will be throwing off multiple Check Engine Codes.
Is there anyone you could get me in contact with who could help in the matter?
Any assistance is greatly appreciated.
Thank you.
[b][/b]
AZJowett #825518 17/06/25 12:11 PM
I believe the unlock code S&S are referring to was actually embedded with the Stage 2 map. The update unlocked the ECU, flashed the Stage 2 map and then relocked the ECU.
If this is wrong and you can get an unlock code out of Morgan then you will become a very popular chap as many of us have spare locked ecus from when we purchased an unlocked or replacement ECU as part of the 569 installation.
Do let us know how you get on with Morgan.
Red Leader drive
AZJowett #825527 17/06/25 03:51 PM
Just got this reply...
"Hi Scott,
55-5090 is a CTO model that allows the customer to select a calibration. We should have one that covers this configuration. Rob can assist you with getting you sorted out.
Thanks,
Charlie Hadayia
Executive Vice President of Business Development
Cell 608-574-4095 | Direct 608-627-0387 Ext 1387"
