Topics49,869
Posts837,665
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
My 4/4 is a late 2011 car, which I bought new.( Royal Ivory). Today thought I’d touch up some stone chips. Found the touch up pack that I got with the car which I had used once about 10 years ago. Well the paint in the touch up kit is a lot whiter than the paint on the car, significantly so. Also I used a little car tech 9000 grit finisher on a scratch. You can just see the lighter hue showing through where I rubbed it. But it is very difficult to see the difference. Why would the car’ s paint be going darker. I thought if anything it would be lighter. I guess if I want it corrected, (probably not) a professional valater could re condition the paint. Any other suggestions?
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Unless the touch-up paint came from the same batch that the car was originally painted with, one might expect some slight differences.
Posts: 1,019 Likes: 120
Posts: 1,019 Likes: 120 |
Take the car to a body shop and they will scan it, that way you will get the correct colour as it is now. In your documents you should have a thin metal paint swatch, about 6"x3". check that against car and you only need to take that if it still matches.
Thanks Sewin, I’ll take the car. Rgds Bob
Posts: 1,400 Likes: 258
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,400 Likes: 258 |
Mine is Royal Ivory. When I first owned it when it was new in 07 it was certainly much lighter than it is now. Second time around it's a much darker and creamier colour.🤷🏻♂️
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
If your tin of touch up has laid dormant for 10 years it will need a surprising amount of stirring / agitation to raise all the pigments in the sediment
My tip is to drop a stainless steel nut in the tin to help mixing
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
Always, always get the paint scanned. Any car, any age.
