2 members (Julian BB, RichardV6), 185 guests, and 95 robots.
+8Rich 78
Topics49,872
Posts837,689
Rudolf
#825950 23/06/25 08:46 PM
IcePack Offline OP
My 4/4 is a late 2011 car, which I bought new.( Royal Ivory). Today thought I’d touch up some stone chips. Found the touch up pack that I got with the car which I had used once about 10 years ago. Well the paint in the touch up kit is a lot whiter than the paint on the car, significantly so.
Also I used a little car tech 9000 grit finisher on a scratch. You can just see the lighter hue showing through where I rubbed it. But it is very difficult to see the difference.
Why would the car’ s paint be going darker. I thought if anything it would be lighter.
I guess if I want it corrected, (probably not) a professional valater could re condition the paint.
Any other suggestions?
Unless the touch-up paint came from the same batch that the car was originally painted with, one might expect some slight differences.
Take the car to a body shop and they will scan it, that way you will get the correct colour as it is now. In your documents you should have a thin metal paint swatch, about 6"x3". check that against car and you only need to take that if it still matches.
IcePack Offline OP
Thanks Sewin, I’ll take the car.
Rgds
Bob
formerly known as Hugh Jorgan
Mine is Royal Ivory.
When I first owned it when it was new in 07 it was certainly much lighter than it is now.
Second time around it's a much darker and creamier colour.🤷🏻‍♂️
If your tin of touch up has laid dormant for 10 years it will need a surprising amount of stirring / agitation to raise all the pigments in the sediment
My tip is to drop a stainless steel nut in the tin to help mixing
Always, always get the paint scanned. Any car, any age.
