8 members (mph, MartinB60, Morganmike, DMC1904, DJC, Graham, G4FUJ, John V6, nick w), 293 guests, and 43 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,337
Members9,215
Originally Posted by John Winn
Bank Holiday on Monday
Oops, yes, Tuesday! Unless the fuse turns out to be the issue. Good suggestion, thanks.
MY2023 Plus Six "Rachel"
MY2022 Volvo C40
Well, it's not the fuse. A call to MMC on Tuesday, then!
MY2022 Volvo C40
Sorry to hear that. Does the USB port work? If not the power supply might be loose.
2025 MG ZS EV aka Trigger
On the MY23 Plus Six the Bluetooth module and USB have different fuses. I think the power supply to the Bluetooth was either dislodged or removed and not put back when the dash was removed by MMC to check the earthing behind. They were chasing a "Drivetrain" fault which they thought could be either fuel supply or earthing, and starting at the back were working their way forwards.
Good news is the Drivetrain fault seems to be solved, but frustrating that in doing so another, albeit less serious, issue has been created doh
MY2022 Volvo C40
Fixed. A call from Morgan Service: "Disconnect the negative terminal of the battery, leave it for five minutes and then reconnect it."
Simple solutions are best cheers
And in disconnecting the battery I tested the Global Telemetrics response team ... "We have detected that the battery has been disconnected on your Morgan" call
MY2022 Volvo C40
And ... it's happened again. Called in to a petrol station to fill up with E5 on the way down to Mogfest, Bluetooth was working when I got there, wasn't when I left. I didn't have the tools to do anything with it over the weekend, so now it's negative terminal off time again, but a call in to MMC as this is treating the symptom, rather than the cause!
MY2022 Volvo C40
I wired a radio in to the amplifier and find it much better than the Bluetooth. I get all music from the phone as well through the radio and all is controlled by the app which came with the pioneer radio. The real benefit is that full control of the speakers comes through the radio as is front to back balance. P M me if you want further details.
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Thanks Robbie, I’ll send you a PM re the radio.
The disconnect worked, but is a sticking plaster. To make it easier when, not if innocent, it happens again, I fitted a Richbrook Discarnect battery master switch with fuse link. It will make it much easier to disconnect the battery and has the added benefit (as and when needed) of providing additional security against theft.
MY2022 Volvo C40
