0 members (), 206 guests, and 46 robots.
Posts837,249
X
xc68anc Offline OP
X
my Plus4 isn‘t starting, so there are some parts I had a look on. In cause the next MORGAN dealer is a lot of miles away I look for
another way.
And found it.
Relais for fuel and immobilizer BOSCH 0986AHO 135 (about 4,-EUR)
Camsensor HELLA 6PU 358380-681 or METZGER 0903271 or LandRover LR084884 (about 25,-EUR)
Ignitioncoil BOSCH 0221604700 (-8SE) about 55,-EUR
may be it helps sometimes.
Greets René
2018 plus4 (sports green)
1 member likes this: Hamwich
X
xc68anc Offline OP
X
ATTENTION! I cause I couldn‘t edit the post, an important update!
After some miles of testdrives the MOG doesn‘t run well. Missing some horses and rough running.
This was caused by the BOSCH Ignition Coil. If you fit a FoMoCo coil and a BOSCH than check how they fit. With the screw removed press down the coil and feel how it fits to the spark and the fixingpoint. The FoMoCo will sit straight and okay, the BOSCH fells „wobbling“.
This „wobbling“ will cause that the spark don‘t fire allways in the right way.
As the FORDman told me: we‘ve got sometimes problems with aftermarket coils.
Greets René
