7 members (John Wilcox, Ruut Bianchi, jejemek, GrumpyPa, Montegue, Graham, G4FUJ, James B W),
258
68
Posts837,273
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I noticed that my coolant was down and there were drips below one of the small bore pipes where they enter the top of the expansion tank. The pipe was cracked in a number of places and the pipe was rock hard. The pipe was marked as Semperit tu 25 so Googling it (for a replacement) it turns out Morgan had used fuel line not coolant line, the temperature range being -40c----- +80c which is obviously not suitable, I have now ordered coolant pipe -40c-----120c. My car is 2013 I would suggest others with a similar vintage check their coolant pipes as there is a danger of the pipe failing completely.
2 members like this:
Graham, G4FUJ, Hamwich |
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
Probably what they had available at the time your car went into build Keith! Good find
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Or a PO replaced it with a bodge.
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Thanks Keith - will check tomorrow.
Or a PO replaced it with a bodge. No I am effectively the first owner, It came from Morgan at 10 months old. Morgan family car.
Posts: 8,656 Likes: 407
Posts: 8,656 Likes: 407 |
Once new pipe in place Keith and with warm engine nip up the clips a tad more.
Once new pipe in place Keith and with warm engine nip up the clips a tad more. Will do Richard.
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
My 2005 car had the same issue. The pipe failed at the other end. Yet another call out for Morgan Rescue.
Ken
WOW 2005. I think everybody should be checking then, Semperit tu 25 is visibly stamped on the pipe.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
The pipe on my 14 year old plus 4 with 55k miles is still like new. It is stamped NBR/CR amongst other numbers etc.
NBR is Nitrile Butadiene Rubber which is good for up to 120 degrees. CR is Chloroprene Rubber (neoprene) which is good for up to 140 degrees.
So the hose is a blend of the two with NBR giving resistance to oil, fuel, abrasion and high temps. The CR adds resistance to weather, ozone and temperature stability.
