0 members (), 341 guests, and 83 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
#826945 10/07/25 02:13 PM
britmog Offline OP
I am replacing the water pump on my 1994 3.9ltr +8. I last took the pump off in 2005 and can't remember if I removed the radiator and grill to gain access or just removed it in situ, any advice please?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Hi Britmog, I've just done this job recently. There's no need to take off the radiator and grill because it's the top bar of the crosshead that limits access. You will have to take the pump off with one of the long bolts still in the pump cause there isn't enough clearance to withdraw the bolt. On reassembly mount the bolt in the pump before offering it up.
If you have a problem with the pump, although originally it's a Triumph Vitesse pump, it has a shorter nose to clear the crosshead so probably a special for Morgan. I was unable to get a new pump and had the original rebuilt instead. I say rebuilt but I think it just had new bearings pressed in. The bottom line is the car is back on the road.
1994 +8, BMW Calypso Red.
How do you open the boot?
britmog Offline OP
Excellent, thank you.
Bruce
2013 M3W (Olga)
Sorry, Rover SD1 Vitesse, not Triumph!
The water pump gasket is also SD1.
