7 members (CooperMan, Detlev V6, BLUE+4, PJH, Pigiron, G Walker, Gordon D), 291 guests, and 66 robots.
+8Rich 95
Posts837,264
TBM Offline OP
Thought I'd post here rather than For Sale/Wanted as there's room for discussion.
As my Mog is transitioning to 'RatMog' I fancy doing a new dash - my current dash is old and tatty and needs a freshen up, but I'm not a big fan of the bling walnut style,
I'm thinking something like Keith's dash, but in brushed/satin aluminium.
So, ideally I'd like another dash that I can either use as a template, of just put an ally cover over so I can then take out the old and put in the new without too much time off the road.
Does anyone have anything lying around orleft behind after an upgrade?
Current dash is like this (not mine)
Also, am I right in thinking that it is just held on with those screws in the bottom left and right corners?
Phil ... I have this one left over from my ali dash swap .... just cluttering up my workshop loft so you're welcome to it if it's any use ... let me know and I'll find a way of packing it up 🙂
Mine just seems to have the two screw fixing points.
Ps ... it has a few old scrutineers labels on it but they'll come off easy enough if you need
TBM Offline OP
That would be absolutely perfect! Thank you.
Let me know how much postage is and I'll bank transfer - I'll send address details via PM.
You could use a vinyl wrap - I suspect there are a multitude of options that would get close to the look you are looking for.
Costock, UK
Disco 5
1 member likes this: TBM
Paul ... he's a biker ... more likely to use 1/4" steel plate ... then paint it with aluminium paint to make it lighter!! 😆
3 members like this: CooperMan, DavidR, TBM
I'd investigate hydro-dipping to cover the dash
Ian S
2019 Sports Green Plus 4
2025 Hyper Blue Mercedes 180 CLA
TBM Offline OP
After discussion with the boss, going to go for similar to Keith - use his as a template and then make one out of plywood with a brushed ally skin. Change the black plastic switches for toggles, and stick a stereo in the space where the glovebox was....
Watch this space......
1 member likes this: +8Rich
Phil, really looking forward to your current journey progressing.
