Posts837,275
Posts: 2 |
Hi, has anyone replaced the figure of 8 Exhaust Tail Pipe rubber hanger? I am struggling to get the bracket over the large, l shaped flange at the end of the exhaust and car brackets, has anyone got experience of doing this? Thanks
Posts: 201 Likes: 8
Posts: 201 Likes: 8 |
Should slip on easily if everything is aligned, make sure you use a smear of washing up liquid to lubricate everything first.
Mike H Bourgogne Franche Comté
Posts: 5,432 Likes: 466
Posts: 5,432 Likes: 466 |
I and others (non-Morgan) have used petrol on the rubber item to make it less grippy and more inclined to slip over obstinate obstacles. It takes no more than a splash or two but best to work fast before it evaporates....Of course one has to be WELL aware of the dangers of using petrol and more so in an enclosed space.. Good luck.
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Go on the bay and an exhaust hanger tool is fairly cheap and a joy to use!
Posts: 117 Likes: 21
Posts: 117 Likes: 21 |
Hi Simon
My car is a 1999 4/4 and has a figure of 8 exhaust hanger at the rear. I replaced it with a polyurethane mount from a company called Powerflex part number EXH003 supposed to last for ever. Fitted using washing up liquid it was a doddle.
Tony
1 member likes this:
Mick Annick |
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Blob of Vaseline & some grippy rubber gloves does the trick...ooops wrong forum
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Hi, has anyone replaced the figure of 8 Exhaust Tail Pipe rubber hanger? I am struggling to get the bracket over the large, l shaped flange at the end of the exhaust and car brackets, has anyone got experience of doing this? Thanks When I saw who started this thread I thought I’d done it in my sleep 🤦♂️🫣😳
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
