5 members (PaulJ, Plus Four Guy, howard, Barry M, davewhite), 376 guests, and 85 robots.
Topics49,849
Posts837,411
DazMog, The Impaler, tlchzj79
#815540 14/01/25 08:01 PM
Robrhi Offline OP
I have just been given a mesh front grill that fits behind the original. How difficult is it to fit? Any advice welcome. Thanks in advance.
Robrhi #815542 14/01/25 08:13 PM
Depends on the trad. Later cars had tabs on the inside of the grill to hold the top.
The two bolts that hold the grill at the bottom pass through the grill
Robrhi #815547 14/01/25 09:07 PM
As John suggests it simply hooks onto inside top of main grill and the pair are then pushed up into a slot on inside of cowl being sandwiched in place at the bottom by the two lower grill bolts also holding numberplate box if fitted.
Robrhi #815553 14/01/25 09:39 PM
I found it easy. Just take your time as it is easy to scratch the paint on the cowl.
Costock, UK
Disco 5
Robrhi #815632 15/01/25 09:33 PM
Put some masking tape around the paintwork of the cowl edge...better safe than oops !
Robrhi #815639 15/01/25 10:12 PM
And also pay attention to the skin of your fingers.
The edges of some mesh grills are as sharp as razor blades!
RichardV6 #827953 30/07/25 10:58 AM
E
E
Should the car be jacked up or on a bridge to fix the mesh to the radiator grille ?
Bob Evo
Robrhi #827964 30/07/25 02:11 PM
Tis a lot easier if you raise the car and put the front on axle stands as it removes the angle that helps prevent contacting the cowl but it still can be done on the ground!
Evolution 44 #828037 31/07/25 03:11 PM
X
X
I made a homemade mesh. Very easy. Undo the numberplatebox and than you can pull the waterfallgrille out.
At the back you‘ll find on the upper side two hooks for to fix the mesh. Put the both parts back an fix them with numberplatebox.
To lift or Jack up the the MOG is a personal taste of work and not nessesary.
Hallo, ich habe mir einen „Mesh-Einsatz“ selbst gebaut. Sehr einfach. Aber egal welche Art des Zusatz-Meshgrill montiert, die Vorgehensweise ist gleich. Man demontiert die „Nummerschildbox“ und schon ist der Orginalgrill lose. Der ist oben gesteckt und man kann ihn dann recht einfach herausziehen. Im oberen Bereich des Originalgrills sind zwei U-förmige einfräsungen, diese Nasen etwas herausbiegen und den „Mesh“ einhängen. Eventuell mit etwas Nachdruck schön passend formen. Wenn das paßt den Mesh mit zwei Kabelbindern sichern.
Dann die Kombination wieder einfädeln und mit der Nummernschildbox wieder befestigen. Kabelbinder entfernen.
Tatsächlich kann man sich bei der Aktion eine Macke in „Nase“ (des Autos) hauen, daher rundum etwas Tesakrepp oder ähnliches ist nicht verkehrt.
Achja: Schneidersitz, kleiner Hocker oder ähnliches reicht.
Viel Spaß beim Basteln!
Gruß aus Mainz
René
2018 plus4 (sports green)
Robrhi #828043 31/07/25 03:52 PM
Black Rat
Black Rat
I agree, undo number plate box and then easy job no need to jack up.
Keith
2013 narrow bodied + 4 Ruby.
1 member likes this: xc68anc
