7 members (John Wilcox, Ruut Bianchi, jejemek, GrumpyPa, Montegue, Graham, G4FUJ, James B W),
258
68
Posts837,273
Posts: 1,042 Likes: 148
Posts: 1,042 Likes: 148 |
Might be worth fitting a nylon block such as this Peter. ![[Linked Image]](https://i.imgur.com/SKWuiXd.jpg) I gained 30mm by removing the ridiculous bell housing lip, and then surgically inverting the crossmember. https://www.talkmorgan.com/ubbthreads.php/topics/801930/1Next on the list is the gearbox mount that excessively protrudes right in the centre of the car (the breakover point). I'm confident I can gain 20mm here with a redesign of the mount, add a set of 205/65 tyres for a further 14mm lift and the lowered Monty will actually have better ground clearance than a standard Plus 4.
Posts: 8,656 Likes: 407
Posts: 8,656 Likes: 407 |
In Germany there are police „special forces Carspotter“. If they realize wrong tires, it isn‘t funny. Also the MOT would be a problem. About the groundclearence I‘ve got a massive alloy shield from WOLF? fitted by BHM. But the most time I think the scratching noise is from the VERY long screws for the seatrails. And: the last time we travelled by P&O I think we hit something at the ferry with the rear valance. This part: https://www.wolfperformance.co.uk/product/trad-chassis-cross-member-rub-plate/Greets René Shortening the overlong seat rail bolts the factory insist on fitting are the very first job you should do particularly the rear ones that pass through the cross member. Inner ones seen here at bottom of pic in view from rear looking forward. ![[Linked Image]](https://i.imgur.com/lb6QGEG.jpg) Fortunately a very easy job if you have a helper. One was found already bent on mine despite minimal mileage, but managed to get nut off ok. Replace these with nylocks if not already present.
1 member likes this:
xc68anc |
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I have 185/70 Avons and have never had any problem with grounding.
