0 members (), 295 guests, and 29 robots.
+8Rich 94
Posts837,276
Might be worth fitting a nylon block such as this Peter.
I gained 30mm by removing the ridiculous bell housing lip, and then surgically inverting the crossmember.
https://www.talkmorgan.com/ubbthreads.php/topics/801930/1
Next on the list is the gearbox mount that excessively protrudes right in the centre of the car (the breakover point). I'm confident I can gain 20mm here with a redesign of the mount, add a set of 205/65 tyres for a further 14mm lift and the lowered Monty will actually have better ground clearance than a standard Plus 4.
Originally Posted by xc68anc
In Germany there are police „special forces Carspotter“.
If they realize wrong tires, it isn‘t funny. Also the MOT would be a problem.
About the groundclearence I‘ve got a massive alloy shield from WOLF? fitted by BHM. But the most time I think the scratching noise is from the VERY long screws for the seatrails. And: the last time we travelled by P&O I think we hit something at the ferry with the rear valance.
This part: https://www.wolfperformance.co.uk/product/trad-chassis-cross-member-rub-plate/
Greets René
Shortening the overlong seat rail bolts the factory insist on fitting are the very first job you should do particularly the rear ones that pass through the cross member. Inner ones seen here at bottom of pic in view from rear looking forward.
Fortunately a very easy job if you have a helper. One was found already bent on mine despite minimal mileage, but managed to get nut off ok. Replace these with nylocks if not already present.
1 member likes this: xc68anc
Black Rat
Black Rat
I have 185/70 Avons and have never had any problem with grounding.
Keith
2013 narrow bodied + 4 Ruby.
