1 members (Hamwich), 245 guests, and 19 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Page 3 of 3 1 2 3
IcePack #828645 12/08/25 02:05 PM
My Roadster was fitted with dimpled and grooved discs when I bought it, and they were unremarkable. The Hi Spec ventilated discs and calipers I have now did not deliver the bite and feel I expected either.
I fitted Brembo discs & pads on my Golf, and the transformation was incredible.
IcePack #828666 12/08/25 09:16 PM
I think the drilled and/or grooved discs are to clear gases from between the pads and disc.
DB
IcePack #828722 13/08/25 08:27 PM
True but also to dispel water, brake dust etc. so keeping the braking surface clean. The machining also improves heat dissipation due to greater surface area so reducing fade.
IcePack #829744 31/08/25 09:53 PM
Happened to me today heavy rain came to brake strong pull to the left which took me by surprise and yanked tbe wheel left. Remembered this thread after I gained my composure and dabbed the brakes every so often and was fine
Certainty worth remembering for the future
When I got home checked the rakes all free and normal my car is a 2015 plus four gdi
IcePack #829758 01/09/25 10:55 AM
Yep, it's the wire wheel phenomenon! Seems they think they are propellers! However I had often wondered why is it that the off side wheel can suffer sometimes more than the near side wheel which is generally running in greater levels of water.I thought that perhaps the calliper pistons might be relaxing more on one side than the other and letting water sit there but no, the phenomenon continues. One day when I had nothing better to do and was tidying up around the place I came across a set of old disk guards I had for a Mexico which I had at the end of the 70's. the plastic type that stops brake dust getting on the alloy wheels. With a bit of modding I fitted it to the brake disc and despite the fact I really don't like taking my car out in the wet I waited for the next rain storm and took it for a blast.... The covered disc clearly didn't suffer with the problem and in heavy water when the problem showed itself the car only pulled to the right (protected disc) side. So it was clearly staying dryer. Now I at first thought that it was a hot disc sucking in water after a total soaking and a rapid cooling from same allowing water to flood in between the disc and pads, but I'm not sure how hot my disc's or pads get as I rarely need to hard brake so I reached the conclusion that the wire wheels just can and do give the disc's a thorough good soaking and its just hit or miss as to which side gets it! A quick stab and straight back on the brakes seems to have a clearing effect, a practice I have now adopted if ever caught out in heavier rain.
IcePack #829771 01/09/25 02:38 PM
Could it be the lacing of the spokes, near side and off side spin differently?
DB
Page 3 of 3 1 2 3
