11 members (nick w, 2949olivier, stumog, Fuel.inj, Strathaven, +8Rich, MartinB60, Guten, nestor59310, Graham, G4FUJ, James B W), 307 guests, and 40 robots.
+8Rich 92
Posts837,279
#830926 21/09/25 01:41 PM
Hi, I have sourced what appears to be a good product to use for cleaning my Plus4 chrome wire wheels, ( “Mothers” pro strength chrome wheel cleaner). but I cannot find a suitable brush for getting between the spokes ? ( and certainly do not want to use a toothbrush like I used to do on motorbikes !! )
Can anyone recommend suitable brushes please ….. ?
I use these
Item on Amazon
Ian S
2019 Sports Green Plus 4
2025 Hyper Blue Mercedes 180 CLA
These wire brush sets are useful I find for cleaning up small corroded parts or difficult access areas.
Steel, brass and stiff nylon bristles. The latter are ideal for encouraging metal cleaners to work without damaging metal finish, so great on spoked wheels.
Originally Posted by Saxonian
I use these
Item on Amazon
I use these
Item on Amazon
I presume that is a “wheel off” clean when using these ropes ?
MWS, who supplied your Morgan's wheels, used to offer a wire wheel cleaning kit which worked well, although now discontinued. They still offer individual cleaning aids here though via their online shop. Probably the most useful is the cleaning and protection fluid below.
1 member likes this: SteveMerch
The Mother link below seems to indicate it’s a spray on and hose off cleaner.
https://motherscarcare.co.uk/produc...vhiQQlsp1fsYUa-7ePGx_roDy4Y4LsGbJ-guzPaY
Have not personally tried it. Prefer an old towel or flannel used with a tapered wooden stick to access between the spokes.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
I used the MWS cleaner it works well
I merely power wash my wires then protect with Rimwax.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Quote
=SteveMerch
Yeah - wheels off, generally once or twice a year
Ian S
1 member likes this: xc68anc
Having a ramp makes the job easy with wheels on so can be done regularly. I usually start with inside of front wheels using white spirit on a rag to remove the inevitable drips of grease from suspension which ends up as a uniform layer - this despite having cleaned off excess after each greasing session. Having stainless rims and wires allows easy cleaning of the rest. In the winter at least I then wipe over with WD40 and clean cloth.
