4 members (gomog, SEG, IcePack, TalkMorgan), 331 guests, and 80 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
Druid9 Offline OP
So would a blown dash light affect the whole right side, excuse my ignorance.
1978 Morgan 4/4 4 Seater Molly
2015 Merc C250D Helga
TBM Offline
I'm no expert on electrics (Richard V6 is your man) but there's every possibility with Morgan wiring!
Druid9 Offline OP
Thanks all, it turns out it is part of an ongoing issue I have had with the ignition switch. My last call for help was around the engine just dying, which was fixed in the same way, by a bit of a jiggle behind the switch. I really must pull it out and see whats going on, but here in Australia it's just coming into peak Morganeering weather, and I'd rather be driving than tinkering. No doubt it will let me down far from home sometime, and then I'll leap into action. I did acquire a new ignition switch when I bought her, but haven't got a roundtuit
Thanks for all your help and constructive suggestions. I love this forum.
2 members like this: Graham, G4FUJ, TBM
Not if it was just that.
Strongly suggest if you have a new ignition switch to replace it now though. It shouldn't take more than a few minutes but do take chassis lead off battery first.
Druid9 Offline OP
Sage advice as always, it's a long weekend this weekend, should be able to find an hour. Thanks.
Druid
My only advise to you is before you start taking wires apart, take pictures. It's so easy to get wires mixed up. On my MOG i have wire from my indicator to a 'block'. I have found in the past a loose connection within the block.
Navy Dave
1976 Morgan 4/4
