8 members (TeddyAds, Aeromax51, MOG42, GrumpyPa, sprinty, CooperMan, MJF, Image),
244
43
Topics49,843
Posts837,348
Posts: 7,363 |
Brian, I'd meant to ask you about that. Although I spent quite a bit of time looking over the MTW at the factory I didn't look specifically at what might limit lock, though I certainly noticed how poor it was during my brief test. I'm afraid that I've done the same Philip, i.e. not looked closely, I'm in Africa now but will look at mine in more detail when I return at the weekend. In view of the wide front track I don't see why it has such a poor lock, maybe it's the rather enclosed mudguards.
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Gone to Porsche Part of the Furniture
Posts: 4,333 |
Bring some nice weather back with you pleeeeeeeeease
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
Bring some nice weather back with you pleeeeeeeeease  on the turning circle: it almost touches the exhaust on full lock guess those are a limiting factor imho better to change the building-plan
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 870 |
Could it be that they placed the steering rod (the one going from aft of the wheel into the center/steering wheel pipe further aft so it would be easier to turn while standing still?
I mean, if the rod parallel to the wheel - the one going aft from the center of the wheel were a bit shorter, the push-pull of the perpendicular rod would achieve more of a turn of the wheel. Of course, in order for the power needed to turn the wheel, the steering wheel itself would need to be bigger than the standard.
I'm having trouble explaining this in words, a drawing would do much better, but I hope it's somewhat understandable, if not, perhaps I should try with a picture?
Posts: 870 |
Oh! Never mind my attempt at a solution, since my solution would then make it go even closer. Perhaps a combination of lowering the exhausts (i.e. the wheel is narrower further down) and the shortening of the rod going from the center of the wheel could be workable, as far as I can see.
getting to "drift" it very controlled then no turning is neccesary
Posts: 536 |
AQM, I think I understand what you are saying. Assuming track rods go out perpendicular to the wheels, the further the steering rack centreline is away from the wheel axle, the more rack movement is required to turn the wheels.
Cheers
Philip
1985 Plus 8 four seater Malone F1000 - track car
Posts: 870 |
Cheers Exactly, Phillippo!
Posts: 205 Likes: 1
TM Photographer of 2011 L - Learner Plates On
Posts: 205 Likes: 1 |
Chapeau! Thanks for sharing these very good pictures.
Baby Doll (Westminster green).
Posts: 7,363 |
Question, what's the front tyre pressure?
Interested as the front tyres are exactly what I run on my vintage trike. Suspect it'll be a pound or two more pressure than I use as the new three wheeler is heavier. I use 19 psi at the front, and 25 psi at the rear - completely different rear tyre. According to the handbook Martyn, the correct pressures for cold tyres are as follows: Front tyres - 22psi or 1.5bar Rear tyres - 25psi or 1.7bar I don't know how that compares with the ones on your vintage trike.
Brian
