2 members (TBM, Image),
237
78
Topics49,870
Posts837,670
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
From personal experience I’d look at A) urban cooling fan blade loose or fan housing rattling against the engine. B) the headlight bowls cracking at the base and rattling. I would add shake the headlight a little as the connector inside can rattle against the shell. Liberal use of foam/tape inside will cure it.
Red Leader
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
I would add that taking a good, hard look at everything on the front end. I found that if you regularly drive, then taking tools out to tighten everything back down is a necessary step in preventative maintenance. This car is literally trying to shake itself apart all the time. Your noise could be anything and anywhere.
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
Suggest using a rubber mallet and tapping all around the area where you think rattle is coming from. For me I discovered a rattle of mine which I originally thought was engine-related actually came from within headlight. I did this and it seem the bit on the exhaust that moves ie the part of the exhaust the side exhausts connect to does make a rattling sound when it with the rubber mallet but the passenger side doesn't. Looks like something I have to put up with.
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Posts: 363 Likes: 37
Posts: 363 Likes: 37 |
If you mean the exhaust flexible joint part then your probably find its split the flexible part below the woven outer part. You will also notice exhaust gasses coming out said part. You can get a replacement flex part and take the header off the car to an exhaust specialist to get it replaced.
Or the other thing it can be is especially common on Euro4 cars, the cats come loose and rattle. Had one where 3 of the 4 cats had come loose.
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
…….Or the other thing it can be is especially common on Euro4 cars, the cats come loose and rattle. Had one where 3 of the 4 cats had come loose. If that’s the reason, then it’s likely to be an MOT failure, so best not to ignore?
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
In the UK the emissions are not checked on the MOT for M3W's. The easy solution for loose cats would be to remove them. Maybe not so easy on a Euro 4 header I suspect but a fairly simple operation on Euro 3.
