8 members (cerealsurfer, BLUE+4, Craig Jezz, linklaw, Julian BB, RedThree, +8Rich, rossocorsa),
268
45
Topics49,843
Posts837,336
Posts: 37,405 Likes: 977
Posts: 37,405 Likes: 977 |
What are you all finding the best Everflex waterproofer please.
Also the best aerosol black underseal for touching up the odd road kill /grounding spots.
Thank you.
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Posts: 51 Likes: 17
Posts: 51 Likes: 17 |
Everflex -Autoglym Vinyl & Rubber Care Underseal - Tetroseal Wax/Oil Rustproofing Black
2002 4/4 Zetec Indigo Blue purchased July 2023 my first Morgan
Thank you both, now ordered up.
Posts: 8,662 Likes: 408
Posts: 8,662 Likes: 408 |
The black Tetroseal waxoil is great but beware the paint additive is very tenacious and so difficult to get off (including your hands). I use the clear equivalent near exterior paintwork which allows excess to be readily removed with white spirit.
Thanks Richard, I think the car came out the factory in 1999 with the black stuff as I am always covered in the black goop when working underneath her.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Bilt Humber underseal was my choice on the trads. It didn't harden and crack, maintaining a bit of self healing. It washes off with white spirit. Mask off areas to keep clear then spray on. Autoglym vinyl/rubber cleaner. Renovo do kits for rejuvinating vinyl roofs. The awkward problem is sealing the sewn seams. Beeswax or seam sealer worked. My roof was tight and the thread holes were the weak spots in heavy rain.
Thanks yes it's the seams on the Sport Everflex that I'm targeting really so a little bees wax, sixteen years old and with 116,500 miles and used as a daily she is in great condition including the roof just in need of a little proofing.
Interestingly the Plus 8 at twenty six years old the mohair roof is tight as a nut, unlike the windscreen rubber lower seal which I shall have to renew sometime. Always use her with the half cover over and side screens off so to be fair it has little use as a roof..
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
If your car has the black stuff from the factory then get a spray can of Dinitrol chassis wax in black and use that to make the touchups. It will fully blend and is a self repairing finish as in rust protection as this was the wax that MMC used. Dirt cheap and available on line.
Everflex shouldn't leak, if it does it's the stiching holes or normal Mog fitting defects. Think Dave W had a solution if its the stiching.
1 member likes this:
+8Rich |
Posts: 27,805 Likes: 749
Posts: 27,805 Likes: 749 |
I used the wax for Belstaf waxed cotton jackets on mine to seal the stitching.
+8Rich |
