Hi John, thank you very much.
The fuel pump is working. I don't think that's the problem. Okay, the filter would be a new option.
What is the ECU? What can I do about that? Sorry, I like tinkering with cars, but I'm not a professional. ;-) regards Sven
My 93 T16 has no mobiliser and the ECU is different to yours and likely not in the same place on the bulkhead but most likely a square rectangular flattish metal box, it controls fuel and ignition.
You might need to unbolt it to read the MKC number. You can try to get it repaired or get a second hand one on Ebay but you will need to get it programmed to the immobiliser or get the immobiliser removed by a specialist.
Perhaps a TMer with a 98 T16 could be more help with the ECU information and the fuel pump relay position (to do a temporary swap).
keep trying Sven, regards John k
