Topics49,841
Posts837,318
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
Given the relatively short time the battery will hold a charge - 3 weeks, would it not be a good idea to disconnect the battery when leaving the car? Either just undo and remove one of the terminals, or better still fit an isolater switch, which makes turning the power on and off easier and will act as a thief deterrent as well.
I doubt it will upset the ECU or even the tracker, but may lose preset radio stations etc. Does anyone know for sure about this?
I have done this on my ARP4, but then that doesn't have any BMW components, and the battery will remain charged for months at a time when disconnected.
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
All my Morgan's have had a Battery Isolator fitted or I have fitted one.
On restarting my impression is the tick over is higher than normal (1k norm cold start 750) and they run a little rich (safety default) for a few miles until the ECU learns the NEW normal for the car and I never use a charger.
I am old school and seen many a battery destroyed by overcharging with no discharge cycle..
As a battery is a storer of energy it seems somewhat pointless to me to keep it on charge - remove the load is the logic of the situation.
If the tracker is not self powered it's not worth having in the first place.
The Becker loses it's stations but I can live with that as I only put it on in the garage.
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
You can get an earth lead that unscrews as fitted to Peugeots from memory.
The CX Plus Four cars seem fine being disconnected from the battery
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Connecting the battery to a CETEK charger is quick and easy. I do this on my Morgan and have been doing it on my Harleys for years. I have never had to replace a battery.
Clemens
PlusFour Red Baron MY 2022
Posts: 1,912 Likes: 93
Posts: 1,912 Likes: 93 |
Connecting the battery to a CETEK charger is quick and easy. I do this on my Morgan and have been doing it on my Harleys for years. I have never had to replace a battery. Yes, they seem to work well. This is the one I had: https://www.ctek.com/uk/battery-chargers-12v-24v/mxs-5-0-uk
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Recommend one of these - got three on the go at the moment. Maypole 4A Battery Conditioner
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
1 member likes this:
Luddite |
Posts: 988 Likes: 14
Posts: 988 Likes: 14 |
Those Magcode connectors are really useful, I put mine on the rear Valance (Trad though)
Brian
Jersey and Spain
Posts: 139 Likes: 27
Posts: 139 Likes: 27 |
I like the CTEK because the status lights are simple to understand.
I'm wondering if there is an easy way to route the plug into the cabin, to avoid having to open the bonnet?
Plus Six '75 Commando 850 '76 CB750K6
