2 members (DaveK, +8Rich),
346
45
Topics49,904
Posts838,087
Posts: 382 Likes: 3
Posts: 382 Likes: 3 |
Hello All, Looking for your thoughts on installing remote greasing kits. Do they work? Are they reliable? Pros & Cons.
Thankyou, Best wishes for the New year
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
I got mine from Cain @Wolf. They work very well. Far easier to grease but you still need to kneel down to remove the excess & do the spanner check.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Posts: 37,484 Likes: 989
Posts: 37,484 Likes: 989 |
The Plus 8 is one shot oiler and hand greasing bottom end - but our Sons 4/4 Sport came fitted at 115,500 miles and works very well provided you check for excess and tighten everything up down there as John said.
I will say the SSL modification Jeremy had done on Henrietta is a good front end modification.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Depends what year your car is and era of front suspension or if your older Kingpins have been drilled to accept grease from the top if not then grease will not flow through. If older suspension without modification then just make sure the bottom grease reservoir is kept full.
Posts: 731 Likes: 58
Posts: 731 Likes: 58 |
Cat 302 When i brought my MOG back in 2001, it had a remote greasing kit set up. But the thing is the nipples were located in the engine bay. But here is the thing, as you pump away you not too sure how much grease you are pumping. When i rebuilt my MOG, i removed them. Far better to jack the front of the car up and get underneath so you can pump just the right amount, on all the grease points.
Happy New Year
Navy Dave 1976 Morgan 4/4
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 382 Likes: 3
Thank you all for your replies.
I think I will proceed with a Kit. Cheers and happy Morganeering 2026
Posts: 382 Likes: 3
Hello Craig,
Did the manifolds come with kits ?
Your Morgan engine bay looks spotless, keep up the good work.
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
I considered but decided not to fit. It seems a long way for grease to flow reliably. And I probably only grease twice a year. My car (1997 Plus 8 ) has standard suspension, which I like to jack slightly to ensure the grease gets in under the damper blades. My car also has a grease nipple on the top of the strut, but in all honesty, it is not really worthwhile greasing that point as the grease really doesn't flow down that route.
