Posts837,279
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
Re my previous post about hood tenax. ![[Linked Image]](https://tm-img.com/images/2026/01/11/IMG_0322.jpeg)
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Even with the distortion, that looks far more sturdy to me than the original!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 22 Likes: 25
Posts: 22 Likes: 25 |
Hi everyone, A quick update on my Plus Four 75th. I’ve just passed 2,600 km and tomorrow it’s going in for its first control check inspection. It’ll be about a 400 km round trip in one day. They’re planning to fix the hood Tenax fastener, although they weren’t very confident they’d be able to do it  (it’s a new Morgan dealership and the first time they’ll be doing this job, so I’m a bit nervous… we’ll see). This dealership is a Swiss one (I live in France) since it’s the closest one for me. At first, Morgan didn’t want to cover the hood Tenax under warranty, which I can understand since the issue was technically my fault. However, my actual dealership where I bought the car (not the one I’m visiting tomorrow) decided to cover the cost themselves, which I really appreciate. The only other thing I’d like them to check is a squeaking noise that seems to come from the suspension. The more I drive the car, the more I notice it. It’s especially noticeable at very low speeds and when the car is cold. Have any of you experienced something similar? Is it normal? Other than that, the car is still absolutely fantastic to drive. With the sun finally coming out and temperatures rising, I’m enjoying it more and more every day.
1 member likes this:
Luddite |
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Great to hear you really stretching her legs and enjoying her - enjoy your day and don't worry about theTenax.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Mine sometimes squeaks but it goes away. Just enjoy it & drive it like you stole it.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
The Tenaxes are a weak point whenraising/ lowering the roof. The sequence to use is.... Raising...they are the last bit to fit. Lowering....they are the first to release. Mine broke when this sequence was missed. They were plated brass so not the strongest. It is possible to drill out the bit stuck but takes care. You then plug the now empty hole, drill a pilot hole and screw in a new fitting. You MUST do a pilot hole to reduce the force needed to screw in the new part! If not then the new part could easily break as you apply the force to screw it in. I simply replaced mine with two screw versions with the "button" part in the correct place over where the originals were. Masking tape as a buffer, position the replacement cheking level to ground, mark where the holes are, drill slowly, get/make a gasket for between the fitting and panel to protect the paint, fix with stainless screws. Then get into the habit of correct sequence for raising/lowering!
Axool |
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
I also had the squeaking noise for the first 10,000 km or so. Then it disappeared.
Clemens
PlusFour Red Baron MY 2022
Thinking about it mine have too & the car is at 13.8k miles
Posts: 1,392 Likes: 257
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,392 Likes: 257 |
I amazed that in 2026 someone in the Morgan world hasn't had a batch of tenax studs machined in stainless steel or even titanium..........🤷🏻♂️🤷🏻♂️ I'm sure they'd sell like hot cakes.......!!!!!!! Everyone has them.... everyone worries about them breaking........ or pulling out of the panel.....!!🤷🏻♂️ It surely can't be difficult in these days of 3d printing and cnc machining......
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
🇬🇧🇬🇧 Then you end up ripping the hood! If the correct sequence isn’t followed, something, somewhere has to give. Better if Morgan designed it such that a sequence was unnecessary.
CooperMan |
