0 members (), 132 guests, and 38 robots.
+8Rich 104
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,254
Smed., Spanner Juggler
#838646 17/02/26 06:53 AM
GLLOQ Offline OP
To repair my old damaged flywheel, I bought a used MX5 ND flywheel with 20,000 km. I machined the toothed ring before disassembling it so that it would fit perfectly onto the TW flywheel. To finish the assembly, I will use laser welding to avoid softening the metal of the toothed ring.
https://ibb.co/39YWPgSw
https://ibb.co/7xSPysch
https://ibb.co/0jH5ZfH1
https://ibb.co/cXS4Rp7t
https://ibb.co/rRZyfRGx
https://ibb.co/DfX9j20x
https://ibb.co/3DB4FBH
https://ibb.co/gFR8RSHp
https://ibb.co/cXkyk19K
https://ibb.co/KcTGwYzT
1 member likes this: Redfate
GLLOQ Offline OP
[Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image]
3 members like this: atalante83, AZJowett, Redfate
GLLOQ Offline OP
Return of the flywheel after laser welding; the advantage of the laser is the hardness of the metal it deposits and the lack of modification of the assembled metals; it is even possible to weld synchronizing teeth onto gears without softening the metal.
Nice job you re a master
