8 members (RubyMog95, Montegue, Image, Biggle, MATTMOG, Pipmac, mph, Zach), 291 guests, and 88 robots.
Sagging Hood
Topics49,859
Posts837,477
Page 3 of 3 1 2 3
Yes you can remove the bottom section of the door card (to get to the interior door handle mechanism) quite easily - its just a question of removing a number of visible screws, the door pull and the hex head screw from the handle assembly itself. The only minor difficulty with the bottom section of the door card being the screw nearest the hinge which overhangs the running board and requires a very short screwdriver. But in my case it is the section of card above that, that is reluctant to come off. As John V6 has advised, perhaps I will have another go using more force.
2020 PLUS FOUR
2010 Land Rover Defender 2.4 90 Soft Top
2018 BMW 740LD
2022 BMW i3
Originally Posted by John V6
There are tools you can buy or you can use brute strength. I think I used a screwdriver with card behind to protect the leather near the fixing plus pulling the card.. The one right at the front can be left as you can just get access.
In typical MMC fashion the passenger side was a pig, the drivers side easy
Thank you for your advice John. I will have another go using more force. You didn't mention it, so I am presuming the retaining clips or plug or whatever they are, came away with the card and were intact and reusable, rather than being sacrificial and needing a fresh fixing?
2020 PLUS FOUR
2018 BMW 740LD
2022 BMW i3
Looks like an Austin Allegro door handle, and they weren't reliable either innocent
John V6 Offline OP
Yes reusable.
Similar to these on the back panel
Yes reusable.
Thanks. Now I can see what I am dealing with - friction plugs. I guess the wooden frame into which they secure can swell and grip them tight. Anyway I will attack them with renewed resolve later today!
2020 PLUS FOUR
2018 BMW 740LD
2022 BMW i3
Page 3 of 3 1 2 3
