Topics49,859
Posts837,500
Posts: 874 Likes: 157
Posts: 874 Likes: 157 |
With all the interesting feedback I've received, I've realized there are indeed design flaws in this project; the vibration issue is a major concern. If I keep the same rearview mirror shape, I'm thinking of creating vertical folds of material to stiffen the whole thing. I need to rethink all of this…
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Here is the proposal from a certain artificial intelligence...  : ![[Linked Image]](https://zupimages.net/up/26/12/44s5.jpg)
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
Better ask AI to add a safety feature too…  Be careful not to damage your car. The regular mirror supports do have a safety feature should the mirrors be whacked or bumped into, I often walk into mine. The arms are sprung loaded to protects the fixings from being ripped out or even worse, door panel damage.
Roger 2011 Plus 4
Here's version 2.0 of my Grand Prix-style rearview mirrors: shorter, thicker, and more rigid  : ![[Linked Image]](https://zupimages.net/up/26/14/rr86.jpg)
Are you sure that’s stiff enough?  It looks like you may have modelled the latest version using Inventor, if so you could check it? Knock up a simple model of your existing mirror arm and then run them both through the embedded finite element analysis package. Compare the structural strength and see how much better or worse it is than the original. You could even go further and pop a mass on top to do a bit of vibe analysis too
Roger 2011 Plus 4
Here's the next step in the project  : the supports were made of 20/10 stainless steel, and assembly will take place this week : ![[Linked Image]](https://zupimages.net/up/26/18/zlfm.jpeg) ![[Linked Image]](https://zupimages.net/up/26/18/9tk9.jpeg)
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Very cleverly done, but I must see it om the Mog to judge what I really think of it...!!!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
You definitely need a safety feature such as the spring system. Two reasons... Prevent/minimise damage to the car it's mounted on. Prevent/minimise damage to other venicles or objects AND people who get hit by it. If on a kit car I suspect it would fail passing at the inspection phase for edges/projections too "sharp" plus rigidity. Maybe even issues at MOT ( or equivalent outside UK) and a modification for insurance. Non standard part post homoligation.
Well, I admire your skills Nestor, certainly also with the fuel cap and the spare wheel cover plate, but I don't think I will follow you with these side mirrors! But nothing so personal as taste!! Congrats on the job!
