11 members (TBM, nick w, nestor59310, jbk, vbalddave, 2949olivier, Fuel.inj, Montegue, Image, Alan Patterson, Strathaven),
320
40
Posts837,283
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
I thought that too and but I also loosened them right off and it didn’t make any difference at all. Having said that it's made me think if I have tapped it on a little too far. Just sat in car and pulled the steering wheel sharply and it came part way out and clicked. I think I'm sorted and here is the latest picture ![[Linked Image]](https://tm-img.com/images/2026/03/23/IMG_7706.jpg) Thank you all for your help. Really appreciate it.
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
On my 2012 car (same QR adaptor), there are two points at which the adaptor clicks into place, one further back (about 8-10mm) than the other. In the rearmost position, the wheel can slide a small bit fore/aft, i.e. it's doesn't feel completely secured. In the most forward position the wheel is very secure.
Studying my car, I would say your wheel is still not properly secured. The locking balls should be in that rounded groove visible near the weld in your photo. I believe that at the moment the locking balls are clicked into the bevel sided groove that is rearward of the rounded groove.
Steve Late 2012 M3W
1 member likes this:
Jonathan G |
Posts: 263 Likes: 2
Studying my car, I would say your wheel is still not properly secured. The locking balls should be in that rounded groove visible near the weld in your photo. I believe that at the moment the locking balls are clicked into the bevel sided groove that is rearward of the rounded groove. I think you are right which brings your bolts are too long comment into focus. As the bolts are so long I don't think it will push any further forward because the release collar cannot be pulled back any further.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I would agree with Bitsobrits that the steering wheel attachment screws are too long and maybe restricting the release collar. A photo of the screws on my car below for comparison. The second photo you posted doesn't look like the steering wheel is fully engaged. Sorry about my mistake with your posting history, I mistakenly looked at the likes. The Lifeline QR shouldn't be so much of a problem, it is a much better item compared to the later Travens one. ![[Linked Image]](https://www.tm-img.com/images/2026/03/23/IMG_4252.jpg)
Jonathan,
Try rotating the holes in the collar to allow the bolt ends to pass through when the collar is squeezed. That might allow you to get the wheel fully seated. Then find or shorten some bolts!
Steve Late 2012 M3W
Posts: 263 Likes: 2
I decided just to shorten the bolts and now I have finally managed to get the steering wheel to push into the fully engaged position. As I said I haven't taken the steering wheel off since I had it but would say given the length of the bolts it has never been fully engaged. A bit worrying but at least it's good now. ![[Linked Image]](https://tm-img.com/images/2026/03/24/IMG_7709.jpg) Thank you all for your help and if any of you have been like me and never checked your steering wheel get it checked!
Bunny |
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I've currently got the opposite problem - I can't get my Lifeline QR to release! Collar seems to move OK and I've tugged on the wheel as hard as I dare but it just won't budge! ![[Linked Image]](https://www.tm-img.com/images/2026/03/24/78D1DDB1-5352-4DF3-B95E-B7DDCFFE0A88_1_105_c.jpeg) Next, I'll remove the mounting bolts and try again - but I don't think that's the problem as I never had any problems removing the wheel before. Any suggestions that don't include the use of a blowtorch will be welcomed!
Andy
Posts: 263 Likes: 2
I'm 100% sure I'll have that problem too if I ever want to remove it!
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Once my Lifeline QR did not release, more out of frustration I pulled the QR collar back and pushed the wheel forward and back wiggling it side to side and it then released I don't know which movement released the collar. Cleaned it up re-greased and have not had a problem since; touch wood.
