4 members (TBM, IanL, piquet, Barkbark), 269 guests, and 59 robots.
Luddite 50
Posts837,951
#840715 01/04/26 04:51 PM
Has anyone upgrading their stock X-Wedge 121 charging system to the the 38 AMP System? If I need to upgrade my rectifier then moving to the 38A system can be matched.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Isn't battery capacity the main limitation to starting on M3W rather than charging of same thinking
I have not seen anything about an upgraded charging system, can you provide more information? Not really had any issues with the charging system since the rectifier/regulator was moved to the chassis mounting from the engine, a big reduction in vibration damage. The battery capacity does need to be good to crank the X-Wedge over. The standard Banner battery is very borderline even when new.
