3 members (Chris Cosher, WAFU_Tom, JohnHarris), 282 guests, and 33 robots.
+8Rich 92
Posts837,277
Page 154 of 164 1 2 152 153 154 155 156 163 164
Started out a few days ago with the annual ACF50 'dribble', then after cleaning the underside and arches it seamed a waste not to do a full Waxoil to everywhere... that should last a couple of years
3 members like this: 1854sailor, John V6, Graham, G4FUJ
I have tested the Meguiars Mirror Glaze. It's a small bottle 8FL OZ. Photos are not edited, but two are squashed.
One pass delivers this:
3 members like this: 1854sailor, CooperMan, Luddite
I've been a long time user of Meguiar's products, including among them #205, I have never been disappointed in their performance
when used as directed. rtm
Exemplary result on a gorgeous car DaveW. shades
Bert & B1800
1 member likes this: DaveW
Fitted a new Clevis Pin to the clutch pedal today, despite only slight wear and ridging it's surprising how much slop it adds to the travel
I think it's worth an annual check
Finally got around to removing old very rusty screws that hold the central part of the front wings on. Now done with A4 stainless screws & washers.
Maybe worth checking as the running board tends to sag enough to loosen the rubber bead.
I got the AFR gauge wired, calibrated, and the O2 sensor installed in the exhaust.
"Maybe worth checking as the running board tends to sag enough to loosen the rubber bead."
I strongly agree with your assessment Jon, no telling what manner of ugliness is hiding under there.
Hope for you that the issue can be rectified without too great amount of time and/or expenditure. shocked2
Bert & B1800
The Meguiars Mirror Glaze says "for professional use only", why is that?
2012 4/4 75th Anniversary in Le Mans green
Cooperman, I like your wheel arch liners, Any chance of sharing your install technique!
It's the neatest option I've seen. Martin.
1 member likes this: BertL
I strongly agree sewin!
It's a great idea and shouldn't be very difficult or expensive to implement thumbs
Eagerly awaiting Cooperman's reply on the issue... cheers
Bert & B1800
