7 members (Image, +8Rich, How, Jens, jbk, Graham, G4FUJ, Deejay), 310 guests, and 90 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,428
Luddite-Just to set the record straight... somestick
(C2) Corvette four-wheel disc brakes were introduced in 1965. *Note (The drum brake system was still available however, with a $64.50 credit, only 316 of the 23,562 Corvettes built that year came with drums.) The brakes were of a four-piston design with two-piece calipers and cooling fins for the rotors. Total swept area for the new system was 461 square inches, a big improvement over the 328 square inches of the previous all-drum system. A dual master cylinder with separate fluid reservoirs was available on models with power brakes this year. Testers found that multiple stops from 100 MPH produced no deterioration in braking efficiency.
[img]https://over-drive-magazine.com/2024/10/25/1965-corvette-fact-sheet/[/img]
I owned and performed a comprehensive, ground-up, body-off restoration on a 1967 convertible during the mid-eighties. The brakes were definitely up to the task of reining in the galloping 327 ci/350 H.P. when required! cop
Bert & B1800
K, many thanks for the accurate insight. The C3 that I was under belonged to a friend, and was as I described, I guess I should have known that which seems like normal marketing practise would reply in terms of available upgrades.. thumbs
Bert's '67
"A Blast from my Past"
Sunfire Yellow (code 984) Two top '67 L79 327"/350 hp. 4speed.
On a shakedown run,woohoo(temp. road registration) after its recently completed six and half year restoration.
cameraHairline was in full retreat even then...
Bert & B1800
2 members like this: Luddite, Graham, G4FUJ
